If we are having airline PSS (passenger Service system) System, how can we registered with IATA and get IATA code. as an example Amadeus is using 1A, Sabre is using 1S, SITA is using XS etc..
3$\begingroup$ Have you tried asking IATA? $\endgroup$ – Cpt Reynolds May 2 '19 at 13:05
$\begingroup$ any contact details $\endgroup$ – Lasith Harshana May 8 '19 at 9:20
2$\begingroup$ Finding the contact section on iata.org takes about one point seven seconds (on my phone on mobile data). I‘m sure you‘ll manage! $\endgroup$ – Cpt Reynolds May 8 '19 at 10:14
Add a comment
Try below link, you can type PSS system name and get the code for the same. However, not all PSS are IATA registered.
https://www.iata.org/en/publications/directories/code-search/
