Is CPDLC (Controller–pilot data link communications) mandatory by EASA? I have not heard any update that Airlines are using CPDLC. While talking to some of the pilots I heard that they have been instructed to switch the System due to satellite cost. What is the real scenario?
$\begingroup$ Possible duplicate: Which airplanes are exempt from Europe's 2015 CPDLC (Link 2000+) requirement?. While the subject doesn't look like an exact duplicate, it does address this question as well. $\endgroup$– LnafzigerJun 15, 2014 at 1:55
$\begingroup$ A better duplicate: What additional aircraft equipment is required to fly a US registered airplane in Europe? $\endgroup$– LnafzigerJun 15, 2014 at 1:58
1 Answer
according to eurocontrol, http://www.eurocontrol.int/services/link-2000-programme:
The LINK 2000+ Programme started in 2001 and is now in the full scale implementation phase governed by the DLS IR which requires:
• All newly delivered aircraft operating above FL285 to be equipped as of 2011,
• Core European ANSPs to be operational by 7 February 2013,
• The rest of European ANSPs to be operational by 5 February 2015,
• All existing aircraft operating above FL295 to be retroffited by 5 Feb 2015 (unless exempt).
What aircraft are exempt? See page 4 of this pdf: http://ec.europa.eu/transport/modes/air/single_european_sky/doc/implementing_rules/2014_01_22_2nd_exemption_under_29_2009.pdf
