Stall warning and protection systems on essentially all aircraft work by using several hinged vanes on the side of the fuselage (usually at least three, and preferably more), which align themselves with the airflow over the aircraft’s surface, and, thus, provide a measurement of the aircraft’s current angle of attack. The aircraft’s computers then compare the aircraft’s angle of attack to a preloaded value slightly below the aircraft’s normal stall angle; if the angle of attack is lower than this threshold value, nothing happens, while, if the angle of attack is greater than the threshold, the computers sound the aural stall warning and activate the stickshaker.1
These systems, although mechanically simple, have the major disadvantage that they do not actually detect an impending or actual stall itself; instead, they detect when the aircraft is approaching its usual stall angle, and assume that the usual stall angle also happens to be the current stall angle. Which is all well and good, if your aircraft has invulnerable wings devoid of high-lift devices which are magically immune to things like ice and insect accretion, but most aircraft have wings that
  • have high-lift devices on the leading edges, the trailing edges, or both (leading-edge devices, such as slats and droops, dramatically increase the wing’s stall angle, while flaps, mounted on the trailing edge, slightly decrease the wing’s stall angle);
  • can gather considerable quantities of ice (in the cold season) or insects (in the warm season) under the wrong conditions (both ice and insects increase the roughness of the wing’s leading edge [and, sometimes, the entire upper surface], dramatically decreasing the wing’s stall angle); and
  • are possible to damage, including on the leading edge and upper surface (damage to the surface of the wing, especially on the leading edge, increases the wing’s roughness, dramatically decreasing the wing’s stall angle in the same way as ice or insect accretion do).
Stall-warning systems on newer aircraft try to take this into account, such that an aircraft’s stall warning threshold might be set to (say) 25º when clean, 45º with slats extended, and 5º if icing is detected. However, although the aircraft’s clean stall angle is easily measured during flight testing, as is the stall angle with various high-lift-device configurations, the stall angle of an iced, insected, or damaged wing cannot meaningfully be determined in this manner, as it depends on the precise amount, shape, texture, etc., of the ice/insects/damage, which have a near-infinite number of possible configurations; as such, the threshold in icing conditions is mostly a guess, and could easily be far lower, or far higher, than the actual stall angle of a particular icy wing, and most stall-warning systems don’t even try to account for insect smears or wing damage. To make matters worse, icing, insects, and damage are seldom symmetrical between the two wings, such that one wing could easily end up with a considerably higher stall angle than the other; an angle-based stall-warning system will provide no indication of this.
It is, however, possible to detect an impending or actual stall directly. As an aircraft’s attack angle approaches whatever its stall angle happens to be at that particular moment, the airflow over the upper surface of the wing starts to separate from the wing; this flow separation begins at the trailing edge, and the region of separated flow extends forwards as the aircraft comes closer and closer to stalling, until, when the aircraft finally stalls, the flow separation covers nearly the entire upper surface of the wing. This flow separation, and the associated powerful turbulence, can easily be detected by a pressure and/or sound sensor on top of the wing, and this technology was first available over a quarter-century ago; to quote the NTSB:
There is new technology available that can detect airflow separation on aerodynamic surfaces. One new system measures the pressure in the airflow above the upper wing surface with a probe located at about 70 percent chord (varies by airplane), inboard of the ailerons. The system has been shown to effectively detect upper wing surface turbulence associated with airflow separation, both in flight and during the takeoff roll, once the airplane has accelerated to at least 50 knots. According to a Society of Automotive Engineers (SAE) technical paper,77 developmental testing found that:
Conventional stall warning systems, which use a fuselage mounted AOA sensor, do not measure the actual stalling condition at the wing. The key to determining an early stall due to the presence of contamination is to measure the flow directly at the lifting surface. Local velocity changes in a region above the upper surface of the wing provide a consistent indication of an approaching aerodynamic stall even when contamination is present. This method of stall warning also offers new levels of safety during low level windshear recovery and takeoff performance monitoring.
ATR had established a test program that evaluated the effectiveness of this device before this accident. The system was tested on an ATR 72 in January 1994; and it was tested on ATR-42-500 in December 1994. In addition to ATR airplanes, tests have been conducted with the detection device mounted on a Cessna 421 (cabin-class piston twin), a NASA Sabreliner (business jet), and a Fokker 100 (passenger jet). Additionally, wind tunnel tests were conducted with various amounts of surface roughness and ice shapes on various airfoil designs.
A second new type of airflow separation detection system measures the change in sound (amplitude and frequency) of the airflow over the surface of an airfoil. This system had not been flight tested before this accident, but subsequent wind tunnel tests at the NASA Lewis Research Center showed consistent reliability in the detection of airflow separation.
77SAE Technical Paper 922010, Stall Warning Using Contamination Detection Aerodynamics, by Paul Catlin, B.F. Goodrich Aerospace Avionics Systems, Presented at Aerotech '92, October 1992.
(Pages 156-157 [paper report]/174-175 [PDF report].)
Yet, even though systems that detect a stall or impending stall directly have been available for decades, and such systems are able to reliably detect a stall no matter what the aircraft’s stall angle is2 (which a vane-based system could never even come close to doing), the overwhelming majority of aircraft (even the large airliners where a stall would be the most-potentially-catastrophic) still use attack-angle vanes as the basis of their stall-detection and -warning systems, instead of using systems based on airflow-separation detectors.
Why?
1: T-tailed aircraft have a stickpusher as well as a stickshaker, due to the risk of the aircraft entering a difficult-to-recover-from deep stall if the stall warning is ignored; the stickpusher activates at a somewhat higher attack angle than the aural warning and the stickshaker.
2: Or, for that matter, if the aircraft doesn’t know what angle of attack it’s flying at (and, thus, can’t even begin to determine where it lies relative to the threshold) - for instance, because it doesn’t know how fast it’s going.
    $\begingroup$ There are various systems on general-aviation aircraft that use the movement of the stagnation point / line on the leading edge of the wing to trigger stall warnings. bondline.org/wiki/Stall_Warning_System $\endgroup$
    – sdenham
    Apr 19, 2019 at 20:27
    $\begingroup$ You might consider adding the airliner tag here; saying that "essentially all aircraft" have AoA vanes and air data computers isn't accurate when you consider light GA aircraft. $\endgroup$
    – Pondlife
    Apr 20, 2019 at 0:11
  • $\begingroup$ @Pondlife: Done, added. $\endgroup$
    – Vikki
    Apr 20, 2019 at 2:51
31
The short answer is that we want to warn the pilots about an impending stall well prior to an actual stall condition. From a safety perspective, waiting until the airflow starts to separate, or at the onset of buffeting, it's already too late.
By using AOA we can set a very conservative threshold. This AOA threshold can be adjusted by taking into account many factors such as the flaps/slats configuration, airspeed (mach number), etc.
By nature, sensors which work by detecting airflow separation cannot be used to provide this early warning.
  • 7
    $\begingroup$ Nice answer, and welcome to Av.SE! $\endgroup$
    – Ralph J
    Apr 19, 2019 at 5:41
    $\begingroup$ If you ever fly with tufts on a wing, you’ll see that the airflow can get disturbed on wing sections well before full-on wing stall. So I think this sort of sensor would in fact give early warning if positioned correctly. $\endgroup$
    – MikeY
    Apr 19, 2019 at 22:49
    $\begingroup$ In looking into my comment about stall warning devices, I found, in the US airworthiness standards for transport category airplanes, 14 CFR § 25.207, which states specifically how much before the stall the warning should commence: law.cornell.edu/cfr/text/14/25.207 $\endgroup$
    – sdenham
    Apr 20, 2019 at 15:39
  • $\begingroup$ @MikeY Good point, and in airplanes that display pre-stall buffet, that's what is causing it. The standards I quoted above say an acceptable warning may come from "the inherent aerodynamic qualities of the airplane." They don't explicitly say buffet is one such quality, but if it is, then the detection of pre-stall separation would seem to be a candidate basis for a warning device, though it must work in all configurations and not be prone to false positives. $\endgroup$
    – sdenham
    Apr 20, 2019 at 15:47
  • $\begingroup$ @MikeY Unlike on straight wings, on many swept-wings the airflow separation may start at the wing-tips, very close to the control-surfaces, so there is little margin between the onset of stall and some loss of control effectiveness. Also, on swept-wings the stall boundary is much less abrupt than on straight-wings, making stall detection via flow separation more difficult. Incidentally, this is a reason why we need stick shakers to begin with -- on many swept-wing jets there may be conditions with little (or no) natural pre-stall warnings, so an artificial warning had to be introduced. $\endgroup$
    – peekay
    Apr 20, 2019 at 23:12
To expand on peekay's point, the bottom line is that waiting for actual flow separation to occur is waiting way too late for a stall warning system, except on aircraft with extremely mild and benign stall behaviour. For aircraft that do have very benign stall behaviour, you already have a flow separation detection system, known as pre-stall buffet (You can take this to an extreme in a 1-26 glider, which has a nicely progressive stall with a powerful shuddering buffet at its onset, just below minimum sink speed. You thermal a 1-26 just on the edge of the buffet, shuddering and rumbling your way around).
But for lots of aircraft you just don't want to get to or close to stalling AOA in the first place (aircraft with stick pushers have them because the stall itself is potentially fatal, and the pusher is a last chance at avoiding it) and relying on detection of flow separation is of no use. You have to have margin, and that means you have to have AOA.
And not just AOA on complex aircraft. Stall protection computers use the AOA as one of several data inputs. Aircraft deceleration rates and other factors are all included in computing a solution that sets the top of the barber pole, and sets shaker and pusher (if installed) firing points with adequate margin for a particular flight condition.
    $\begingroup$ Can't they slightly distort a small section of wing so it displays detectable behavior earlier than the rest? $\endgroup$ Apr 21, 2019 at 17:20
    $\begingroup$ Airplanes with good stall behaviour do exactly that with various means, like rectangular planforms, stall strips to trip flow early, or wing twist (washout) that makes the tips always see a lower AOA than the root, . They all make the stall start at the root and progress outboard. The turbulence from the separation at the root makes the tail shake. A lot of high performance a/c though, have wings that let go all at once and those techniques aren't really feasible for performance reasons, so you end up with shakers and in some cases pushers. $\endgroup$
    Apr 21, 2019 at 19:17
There are really good reasons to have AOA gauges other than for stall warning, so they are already there. Probably an element of wanting to keep the systems simple?
For the majority of operations the AOA indicators are great. For cases like icing, hopefully you know there is icing, and you are flying with margin. With an iced wing, stall warning can be too late. Still, I’d not complain if I had a true stall sensor.
If the FAA required them, then we’d see them. So probably a big policy element in all of this as much as engineering element.
    $\begingroup$ Except AOA is not simple. AOA sensors are easy enough, but deriving stall from their indication requires a whole lot of assumptions, including feedback (are the slats actually in the position commanded?), and data about the aircraft (weight and balance) you have to trust the pilots on having entered correctly, like fuel. $\endgroup$ Apr 21, 2019 at 17:22
