This is an ATC routing format, introduced long ago, with the IBM 9020 mainframe. The dots are element separators, used because spaces would signify a new field in the flight plan. Two dots separate like elements (ABCD..BEREE
would be two points, J107..J148
would be two airways) and single dots separate unlike elements (BEREE.BEREE1
is a fix followed by a route [in this case a STAR with the fix name in it]).
Two dots do not necessarily mean "direct;" all they signify is a connection between two like elements. But it is true that when the two like elements are both points in space, rather than routes, the meaning is "direct to the next point in space."
The ./.
construct is called a tailoring symbol, and is used to indicate previous routing which has been dropped (PANC./.DDY..MBW.RAMMS5.KDEN
) because it is no longer needed (there may have been ten elements or more between PANC
and DDY
). In other words, once your flight passed ABCD
, nothing between your departure point and ABCD
was needed anymore.
You may also see, on a flight plan strip, three stars: PANC./.DDY..MBW***KDEN
. This indicates additional routing which was not printed on the strip due to a lack of physical space. If you request a "full route" for the aircraft you can see the actual route instead of ***
. (This is not the case for the tailoring symbol, which will not be expanded out on a full-route strip.)
Also, for an added bonus, the /0052
at the end of your route is the estimated time enroute (in hours and minutes) for an inactive flight plan, or your estimated time of arrival (in UTC) for an active flight plan.
There's some history to add here, for controllers, as well. I knew a gentleman by the name of Frank Cox who actually worked on the IBM9020 CHI (Computer-Human Interface) as a Radar Input SME. He told me the reason why the radar route key required spaces between elements (and routes were not allowed), while the AM (amendment button) format required dots between elements-
"I worked in DC with the radar team, in the R&D building, on the second floor. The D-Side team worked in the same building, same floor, two doors down the hall. We never talked to each other."
DXO006
andYQG341
are not points in space but specified radials off of VORs. This is why they use single dots to connect to the fixesBNNET
andDIRKS
. $\endgroup$
