As per SOP on the A320 we first perform the flight controls check and then arm the autobrake to max. What is the reason behind this?
1 Answer
Both are in taxiing SOP.
The reason is in case the spoilers were accidentally left extended on the flight before (or during a maintenance check before the flight by the line engineers).
If that's the case, then pressing MAX
while taxiing before checking the flight controls (spoilers included) will engage the full RTO brakes and surprise the crew, injure a cabin crew member, and/or cause an accident (a ground vehicle thinking you won't stop and is aiming to pass behind but then you stop in an instant).
Source: Operational Liaison Meeting Taxi Procedures (PDF page 7).
I'm guessing someone has done it before.
