I just saw this come out, Goodyear's Tire-Propeller Concept – a combination tire that can also act as propeller (well, more like a ducted fan I guess).
There's a neat video that goes with it, describing how the fan blades need to bend while being used as a tire. (Otherwise, one winter in New England would take them out!)
Any ideas how fast something with say four 18 inch diameter wheel/propellers, and 3-4 inch fan blades, would have to spin to generate enough downforce to actually get 2000 pounds off the ground?
The weight is the vehicle with 4 motors, 300 pounds of batteries, 600 pounds of passengers & baggage; comparable to my 2500 lb max gross weight airplane, but with weight savings of no wings or tail structure, and batteries vs fuel. 4 motor/fans, and allowing (requiring?) the lift off process to be from a stop, so that all 4 motor/fans could be rotated from road use to propeller use (vs rolling on 2 like the video shows). I imagine 14,000 RPM or some high speed would make quite a lot of noise, compared to the takeoff noise of my 180 horse power engine and 86 inch propeller.
Edit: This rim-driven propeller wheel doesn't look like it would have much total blade are for moving air. That would take even more speed, wouldn't it?
The Moller Skycar seemed quite noisy for a comparison.
