Perhaps this isn't on-topic, but is the A-10 effective against tanks (tank armour) when using its cannon?
For example, this page claims:
Using the cannon, the A-10 is capable of disabling a main battle tank from a range of over 6,500 m.
Is that true?
If that were so, why does a "main battle tank" (e.g. an M1 Abrams) have a 120 mm gun -- contrast that with the A-10's 30 mm cannon?
I thought that in WW2 you needed something like a 75 mm or 88 mm gun to be effective against the then-heavy tank armour. And the gun on a "main battle tank" has if anything increased in size since then -- or converted to missile instead of projectile -- is a 30 mm cannon effective?
Is the armour-penetration of an A-10 exaggerated (if it is effective against only e.g. softer armour than main battle tanks)? Does the cannon being mounted in a plane make it especially effective (I'd guess not, the muzzle velocity of a GAU-8 is 1000 m/s and and A-10's airspeed only adds 200 m/s to that)? If it is effective then why isn't that the primary armament of a main battle tank?
Your source quoting 6500m for the gun seems wildly optimistic
Yes, I think so. "My source" was simply one of the top Google search results on the subject. And I'm even sceptical whether they're effective at any range against a "main battle tank" -- that's my question -- maybe something quite a bit older, or lightly-armoured personnel carrier -- that I could believe easily. $\endgroup$ – ChrisW Mar 7 '19 at 1:18
