Flaps are high-lift devices mounted to the rear portion of an aircraft's wing.
  • Some types of flaps increase lift by increasing the wing's camber, or, at least, that of its lower surface (plain flaps, split flaps, Junkers flaps).
  • Most flaps increase lift by increasing both the wing's area and its camber (Fowler flaps, gouge flaps, Fairey-Youngman flaps, zap flaps).
What would one call a flap that increased the wing's area, but not its camber (like the first stage of a Fowler flap)?
    $\begingroup$ A flap that is broken. $\endgroup$
    – CrossRoads
    Commented Mar 2, 2019 at 16:45
Useless flap.
It is always the increase in camber that increases the lift. The reason to increase the chord is that if the curvature was increased too much, the flow would separate and the wing would stall, so the flaps move aft to be able to move down more while still maintain moderate curvature.
The Fowler flaps do move a bit down even in the first step, and the slats move forward and down with (or even before) them, so the camber increases even in the first step.
  • $\begingroup$ ...so how does the increase in wing area avoid increasing lift directly? $\endgroup$
    – Vikki
    Commented Mar 3, 2019 at 3:42
  • $\begingroup$ @Sean, because lift is not proportional to area. It depends on circulation, the ability of the wing to turn the air flow downward and that depends on the whole profile of the wing. The coefficient of lift is usually given relative to wing area so we can compare efficiency of different wings, but that does not mean it is independent of scale. It isn't. Extending the wing without adding camber will not increase the circulation around it, so it won't increase lift either. $\endgroup$
    Commented Mar 3, 2019 at 10:41
  • $\begingroup$ @Vikki-formerlySean: In other words, it's the pesky CL in the lift equation, which is inversely proportional to the area. Also when you increase the chord, the thickness-to-chord decreases, which also lowers the CL. $\endgroup$
    – user14897
    Commented Mar 20, 2021 at 17:08
