Some aircraft have pusher type propellers. In what ways is it different from a tractor type propeller? What's are the advantages and disadvantages over a tractor type.
    $\begingroup$ Do you mean actual differences in the propeller itself, or differences in aircraft performance between tractor and pusher designs? $\endgroup$
    – egid
    Jan 5, 2014 at 20:19
  • $\begingroup$ performance between tractor and pusher designs $\endgroup$
    – Katz
    Jan 6, 2014 at 2:46
  • $\begingroup$ See this answer to a similar question. $\endgroup$ Dec 11, 2014 at 21:48
12
Well one major difference is the blade pitch, pusher props will seem to be backwards.
You must also modify the engine's bearings to be able to support the propeller mounting and crankshaft in compression, rather than tension.
A pusher prop's engine also has to be cooled differently than a tractor, because the propeller is not blowing air over the engine. Therefore some ducting and ram air magic has to be done, or some other system of cooling implemented. Many pusher-type planes have had severe issues with cooling.
Note: some of the next few might not necessarily apply to pusher-type planes where the engine is mounted above the fuselage, like the Lake Amphibian and many other seaplanes, or some other oddities like the B-36. I am talking about more conventional pushers like the Velocity, Beech Starship, or Cessna 337.
Another issue is FOD. A pusher prop will likely be mounted behind at least one of the wheels, which can kick dirt and rocks up into the propeller. Now imagine a prop that is very close to one of the mains. Even on paved runways you encounter rocks and debris occasionally, and it only takes one hit in the right place to produce a failure-causing nick.
Compounding on that last one, when a tractor-type plane takes off, beacause the prop is forward of the center of mass, the propeller will rotate up, away from the ground. But a pusher prop is usually just the opposite: it will rotate down a bit, increasing the chances of a prop-strike. This is one that is heavily considered and worked-around while building pusher-type planes, but while you can mitigate the danger by placing the prop closer to the CM, or making the landing gear taller, you can't completely remove it as far as I know.
Performance-wise, a pusher is theoretically better. This is because the high velocity propwash isn't scrubbing over the fuselage or wing, introducing more drag (or "negative thrust" if you like).
Conversely, a tractor's propwash is always creating extra drag over downstream surfaces - more drag than if those surfaces simply were scrubbed by the plane's airspeed.
  • $\begingroup$ the stream tube that goes through the propeller disc is still moving faster than freestream when it goes over the wing, causing more drag. There isn't (or at least I wouldn't expect) any vortical component to that flow, however, like there would be in a tractor configuration. $\endgroup$
    – costrom
    Jan 21, 2016 at 21:21
