I was trying to model an turbofan aircraft engine using Matlab and Simulink. In the process I have fixed certain parameters to some specific values which are nominal operating values of the parameters. Can anyone please help me out with the values of isentropic efficiencies of compressor and turbine used in the above case?
1$\begingroup$ I'm no aircraft designer, but when you say "used in the above case", I'm not seeing a use case with enough details to get a good answer. Maybe you've provided everything needed, but I'm going to bet more details are necessary. $\endgroup$– FreeManFeb 19, 2019 at 21:02
$\begingroup$ Related: What is the efficiency of the turbine of a modern jet engine? $\endgroup$– user14897Feb 19, 2019 at 21:16
$\begingroup$ Unless you want to model a specific engine, standard numbers are given in the book 'Mechanics and Thermodynamics of Propulsion'. You can find it online. Or, you can look at this site particleincell.com/2014/turbofan-calculator $\endgroup$– AfeFeb 20, 2019 at 22:56
$\begingroup$ Thank you, will look into tat👍 $\endgroup$– smrithi sFeb 22, 2019 at 2:41
1 Answer
An answer is in the table of the linked question: What is the efficiency of the turbine of a modern jet engine?. Column 4 is for modern engines, column 1 is for old engines, about 1960’s technology. So, take your pick. In order to get a simulation running, an exactly correct figure isn’t necessary, something in the ball-park is fine.
The third comment above gives another similar source. Either would be fine.
