Say Cessna 140 as in this video, look like no additional device to make it turnable when it on the ground. It is a single engine and a tail wheel landing gear. Then, how does it turn?
The rudder cable circuit is also connected to the steerable tailwheel through springs that provide a compliant connection. When you push a pedal it also creates a turn in that direction on the ground.
However the arrangement is unstable in the rolling plane. The main traction elements, the two front wheels, are ahead of the center of mass so the thing wants to switch ends, like pushing a shopping cart backwards. So there is no rolling self-aligning tendency like with a tri-gear and you have to actively provide "artificial stability" with your feet.
That, plus the kind of laggy response when the little wheel in the back is turned, with a springy connection, means there is usually a little foot dance going on while you are rolling. When necessary, you use differential braking to help things along if a steering input (a stab on the rudder) isn't having the effect you want.
Once you are rolling above about 30 mph, the rudder itself starts to provide most of your steering control.
Taildraggers take quite a bit more attention and skill to control while rolling, which gives them a bit of cachet that trigears don't, among pilots that are into that sort of thing (like me).
How it all works: In the exploded image below, Item 6, the steering horn, is connected to the rudder itself and it turns Item 26, the steering fork (or half fork in this case), which has the wheel on it (the springs are to provide some give to the connection to avoid over stressing things when the wheel touches down unaligned with the surface).
The interconnection between 6 and 26 has various parts that make it work a bit like a breakout clutch; 6 can turn 26, but if 26 is turned by an outside force above a certain point, its connection to 6 releases and it can caster or swivel freely until they line up again and re-engage.
So when you are rolling and work the pedals, the pedals/rudder turn the steering horn (Item 6) and it turns the fork (Item 26) with the tire as if they were a single unit and the airplane turns. If you are nearly stopped and want to spin around to park, you lock one of the brakes and this puts so much side load on the tailwheel it breaks the fork out of its connection to the steering horn and it's free to swivel.
Later when you are rolling straight and the steering horn and tailwheel are lined up, they lock together again and you have steering control back. The internal breakout mechanism has to be set up so the breakout force required isn't too high (hard to make swivel) or too low (starts swiveling freely when you don't want it to). You don't want it to start swiveling while you are still rolling at speed and using it for steering, or, like shoving a shopping cart backwards, around you go! (It's called a ground loop)
This is a "steerable/free castering" tailwheel and variations of this type of system are used on probably 95% of GA tailwheel airplanes out there. When steering with this system, brake can be used as required to assist with steering because the steering authority is limited compared to a nosewheel but you generally only apply brakes if you really have to, to avoid wearing the brakes out (the springy nosewheel connection in a Cessna 150 is similar).
$\begingroup$ Do you know the rough percentage of GA taildraggers that have a steerable tail wheel? I know some do, but was under the impression that a majority castor freely. $\endgroup$ – Michael Hall Feb 19 '19 at 0:06
2$\begingroup$ I have a friend with a Tiger Moth built in the early 40s with a free castering tailwheel that does't lock or anything. It's a challenge. Other than that you will see two configurations in virtually all cases; steerable or locking/castering. On some larger taildraggers the tail wheel locks straight for takeoff and landing and can be unlocked to caster when taxiing. You control those with brakes-only at slower speed and rudder at high speed. The VAST majority of tailwheel aircraft have steerable tailwheels with a breakout cam device that allows it to caster when you want to spin in a circle. $\endgroup$ – John K Feb 19 '19 at 1:50
$\begingroup$ @jonhk, do you have something like document or picture describing how it work? $\endgroup$ – AirCraft Lover Feb 19 '19 at 12:07
Mainly differential braking is used to control direction while taxiing at low speed on the ground. Above a certain airspeed during take off and landing ground roll the rudder is also effective.
You steer a single engine conventional gear airplane the same as you would a twin - differential braking and rudder pressure. Some tail draggers have bungee links between the rudder and the tail wheel providing limited steering. But for the most part conventional gear airplanes use a free castering tailwheel.
$\begingroup$ As a millennial, I've always found it a weird convention that the term "conventional landing gear" is still used refer to a configuration that hasn't been the normal configuration for landing gear in at least twice the length of my lifetime. $\endgroup$ – reirab Feb 19 '19 at 6:57
2$\begingroup$ Depends on the airplanes you fly. It’s still the norm for bush and aerobatic aircraft. $\endgroup$ – Carlo Felicione Feb 19 '19 at 7:06
$\begingroup$ @reirab - not just millennials find that odd. Someone asked a question about that around here a while back $\endgroup$ – FreeMan Feb 19 '19 at 19:45
$\begingroup$ @CarloFelicione Yeah, I know that it's still the norm for a few segments of the market, but it's hardly what I'd consider 'conventional' these days. $\endgroup$ – reirab Feb 19 '19 at 20:10
$\begingroup$ Remember that tricycle landing gear didn’t come onto the scene until about the mid 1940s - 30 or so years after tailwheel gear was the norm for airplanes $\endgroup$ – Carlo Felicione Feb 20 '19 at 4:55
