-1
Can someone please tell me where to buy aviation headset jack adapter? Audio-out is 1/4", Mic-in is 0.206" (I think). New-fangled (laptop) receptacles are all 3.5 mm single in-out. Thanks.
closed as off-topic by Pondlife, Ralph J, fooot, ymb1, Sean Feb 11 at 3:41
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "This question does not appear to be about aviation, within the scope defined in the help center." – Pondlife, Ralph J, fooot, ymb1, Sean
If this question can be reworded to fit the rules in the help center, please edit the question.
  • $\begingroup$ Monoprice had the audio out adapters. I have never been able to find an audio in adapter. monoprice.com/product?p_id=7135 $\endgroup$ – JScarry Feb 10 at 17:56
  • $\begingroup$ OK, thanks, that's 1/2 of the problem, the audio problem. Ideally, I'm looking for 2-old-into-1-new (audio+mic). Thanks for helping! $\endgroup$ – user9943887 Feb 10 at 17:57
    $\begingroup$ Welcome to aviation.SE! We consider 'shopping' questions like this off-topic, because they're often subjective and answers can change over time. The tour might be helpful if you're new to the site. $\endgroup$ – Pondlife Feb 10 at 18:42
-1
Headsets have two plugs - the larger one has 2 contacts, the smaller has 4. I have mono headset (old David Clarks), stereo may have more. Laptop will have 3: left, right, common.
Best bet is probably real airplane jacks, and then wire to whatever the laptop needs
http://www.chiefaircraft.com/tlx-mic-jk-kit.html http://www.chiefaircraft.com/tlx-ph-jack-kit.html http://www.chiefaircraft.com/tlx-st-jack-kit.html
Click on "learn more" within each for signal descriptions.enter image description here
  • $\begingroup$ Yes, exactly.But I can't believe someone hasn't "productized" your solution, given how common this is. Thanks for your input! $\endgroup$ – user9943887 Feb 10 at 18:00
  • $\begingroup$ My 'phones aren't THAT old -- basically 2012-David-Clark-ripoffs. There must be a modern solution SOMEWHERE! :-) $\endgroup$ – user9943887 Feb 10 at 18:02
  • $\begingroup$ Why would I use Aviation headsets on a laptop? Most of the time they are sitting in my plane. I just happened to have them at home while the plane is being repainted. $\endgroup$ – CrossRoads Feb 10 at 18:43
  • $\begingroup$ Very nice. But I don't have my own plane. It's basically a $$$ thing. $\endgroup$ – user9943887 Feb 10 at 18:55
    $\begingroup$ OK. It's a "shopping" question. I withdraw. Sorry about that. $\endgroup$ – user9943887 Feb 10 at 18:59
