The consequences of a high speed touchdown / high vertical speed are very much obvious. However, what will the consequences be of a low speed touchdown? How severe are they (if any)?
$\begingroup$ Since you refer to "high speed touchdown / high vertical speed" together separated by a slash, I'm wondering if I'm correct in interpreting what you mean is a high airspeed at touchdown accompanied by high vertical speed? And if that is correct, do you mean that the two always go together? $\endgroup$– TerryFeb 5, 2019 at 7:24
1$\begingroup$ @terry I am not sure if my question is clear that's the reason for the slash. I am aware that those are two different parameters with different consequences and level of risk. I basically want to know the opposite. i.e. what are the consequences and risk of a low speed touchdown. (if any) $\endgroup$– Marshallino CoetzeeFeb 5, 2019 at 7:56
$\begingroup$ Related: What is the typical touchdown vertical speed of a large airliner? (From that post, kiss landings are bad.) $\endgroup$– user14897Feb 5, 2019 at 22:51
This is certainly not a comprehensive answer but can get you started. I’m assuming fixed wing non-VTOL aircraft.
A low (forward) speed touchdown, all other things being as close to nominal as possible in that scenario, translates in all likelihood to a steeper than normal landing and can be associated with loss of sufficient lift or even stall and can result in a hard landing or crash. If trying to compensate for loss of lift, the same scenario will lead to a higher pitch than normal and thus add (or replace the above with) a tail strike risk.
A low vertical speed touchdown, all other things being as close to nominal as possible in that scenario, means a shallower trajectory than normal and can be associated with a long flare or a deep landing and as such poses risks around stopping performance (e.g. if the touchdown is so soft that the automatic deceleration systems don’t even realise the aircraft is on ground) or available stopping distance (if all the runway is used up trying to stick the aircraft down, none is left for rollout). Exiting the runway down the far end at substantial speed again is a recipe for significant damage and danger for life.
A touchdown with both (too) low forward and (too) low vertical speed doesn’t really exist, as that would mean a touchdown roughly along the nominal path but with lower speed, and since approach speed is usually calculated to be somewhere around minimum safe speed (i.e. stall speed plus some margin), slowing down significantly means stall, at which point the scenario changes to low forward but high vertical speed at touchdown.
5$\begingroup$ This answer is great but I'd like to add one thing: Low speed at touchdown, depending on how low it is, can lead to a tail strike, because obviously you need a greater pitch angle to avoid a hard landing. Not a great thing if you don't want to lose your job :) $\endgroup$ Feb 5, 2019 at 8:47
$\begingroup$ Thank you for your views. Yes the assumption is correct - just neglected to mention the a/c type. Would a hard landing not be associated with a high vertical speed and higher (forward) speed? Which may result in a longer flare and possible rwy excursion? Would a lower speed at touchdown not be beneficial esp with regard to available rwy and stopping distance? Esp when one would require an early turn-off to accommodate another a/c on a single rwy airport? I dunno if my explanation or interpretation makes sense - i don't know how else to put it...lol $\endgroup$ Feb 5, 2019 at 8:59
$\begingroup$ @lemonincider Thank you, great point. Added! $\endgroup$ Feb 5, 2019 at 19:38
$\begingroup$ @MarshallinoCoetzee Well, sort of. Your first point can occur, too. Both with an early flare (bleeding off too much speed) or a late flare (not pulling off enough sink rate) you can get a hard landing. Generally, we would not associate hard landing with an increased overrun risk, though, as long as the touchdown is in roughly the right place and the aircraft remains halfway functional. If the speed is too high to begin with, and with a normal flare, it’s more likely the aircraft will float forever rather than touch hard. All in all, there’s more ways to mess up a landing than to get it right! $\endgroup$ Feb 5, 2019 at 19:44
$\begingroup$ @MarshallinoCoetzee Low speed at touchdown makes all kinds of sense, among others for the reasons you list. However, as I said in the answer, generally landings are flown somewhere around lowest safe speed already. Consequently, approaching at lower than normal speeds is eroding safety margins and, the slower you get, first increasing then rapidly decreasing the likelihood of experiencing a landing to remember. $\endgroup$ Feb 5, 2019 at 20:02
I'm going to assume "low speed touchdown" means making ground contact at a slower airspeed than normal. Insofar as it can be done safely, slower=better; less energy to dissipate, shorter landing distance etc etc.
"Can be done safely" is the key phrase. Propeller driven airplanes, especially those that are designed for Short Take Off and Landing operations, can use high lift devices and power to slow to a lower airspeed than normal in order to touch down at the lowest possible speed. It's a specialized procedure because there are some risks; the power is being used to manage sink rate and quite a lot of if is required to overcome all the drag of a slow speed STOL approach. Also you are closer to stall speed. There is little margin for error if something goes wrong with that power. The result, if things go off the rails, is a high sink rate touchdown which may or may not damage the airplane. But, you are doing it on purpose and you accept the risk.
Aside from that kind of specialized technique, "lower speed than normal" (as I would phrase it) at touchdown is not a good thing to strive for because the aircraft needs to have a margin of surplus energy through the landing flare to allow the pilot to regulate sink rate without power in the final seconds. That is, when you flare for landing, you are trading inertial energy for increased lift (pitching up during the flare) to reduce sink rate and manage that sink rate until the touchdown. This is especially true for jets, where you generally can't use power through the landing flare as you can with a propeller airplane, because engines must be at idle before touchdown for the lift dump system to work properly.
So if you are slower than you should be, there is very little surplus energy available and if high sink rate develops there is no way to reduce it (it's too late for power to help). Especially in a jet, you don't want to be much below "reference speed" (full flap approach speed) when you start the flare because at that point, with engines at idle, you are touching down no matter what and if you are too slow, some or all of your intertial energy surplus is gone and the pitch up during the flare may not slow the sink rate at all. Then it's BANG, and off to maintenance for a hard landing inspection. Some jets are more forgiving of being under-speed than others. Those with slat systems and multi element flaps are quite draggy in the landing configuration and bleed energy very fast. Cleaner jets with hard leading edges and simpler flap systems can be actually a bit more forgiving of being too slow because they don't decelerate as fast when the thrust is brought to idle.
Large turboprops are different in that power from that big propeller disc has a huge direct impact on sink rate and on deceleration, and on some you carry power right into the landing flare and may use the feathering off of power to control the touchdown (you land a Q400, which has limited nose up pitch angle, that way). Even there though, if you are too slow, high sink rates may develop that you can't catch in time, and wham.
So bottom line I guess is, there is a sweet spot speed for each airplane to be able to land as slow as possible while still having adequate safety margins via a little bit of surplus energy, and the main penalty for failing to observe that speed is high sink rates resulting in hard landings.
$\begingroup$ There are other reasons for varying approach/touchdown speeds. For instance, you might be landing on a rough dirt strip, and want to touch down as slowly as possible to minimize stress on landing gear. Or you might need a steep approach to avoid hills or tall trees... $\endgroup$– jamesqfFeb 5, 2019 at 19:21
$\begingroup$ Yes if you are doing it on a propeller aircraft you will slow below normal approach speed with large amounts of power to arrest the sink. That's a STOL approach. You know going in that if the engine were to quit while doing so, if you are too close to the ground to dive for speed, you are screwed. You are going to hit hard. You can't do that at all in a jet unless you plan to crash. $\endgroup$– John KFeb 5, 2019 at 23:59
