The Boeing 377 Stratocruiser - a civilian adaptation of the C-97, a military transport which would also later be developed into the KC-97 - were derived from the B-29/B-50 family by grafting a large, bulbous passenger/cargo compartment onto the B-29/50 fuselage; this created a sharp cusp in the fuselage cross-section, as can be seen in this photo of a half-built Stratocruiser:
Stratocruiser fuselage cross-section
(Image source)
Such a sharp discontinuity in the fuselage profile would be expected to serve as a stress concentrator in a pressurised aircraft, like the 377/C-97/KC-97 series, and cause accelerated fatigue cracking in and around the cusp, shortening the lifespan of these fuselages; did these aircraft, in fact, experience fatigue problems emanating from the fuselage cusp, and, if so, how were they dealt with?
  • $\begingroup$ The floor in these aircraft takes part of the stress caused by the cabin pressure. It might not be as bad as it looks. But I am no expert in this stuff by any means :D $\endgroup$
    – Jan
    Jan 25, 2019 at 7:27
You can actually see the same effect happening with soap bubbles when they touch and form a flat film connecting them. You can actually still see this type of fuselage in use in the Boeing 717 (Douglas/McDonnell Douglas DC-9). A lot of other narrowbody airliners also have it, but the outer panels fair over the intersection between the two fuselages.enter image description here
It is not the stress concentrating type of sharp corner. That is the natural shape that allows the parts to be in a nice smooth tension at lowest energy. If you made an elastic rubber balloon with a divider membrane creating two chambers and inflated it you would get a similar load distributing shape.
