I am working on an alternative fuel system for my final school research. I am applying it to the 737-800. Now I could not find info on how the internals are situated. Of course pictures of the cabin are widely available. However I am looking for drawings, pictures or graphs on the cargo compartment, systems placement like gear, hydraulics, pumps or whatever. Basically the whole internal volume and what it is occupied by.
This is maybe a bit demanding but any info is really helpful.
closed as too broad by J. Hougaard, Manu H, fooot, Sean, SMS von der Tann Jan 20 at 6:45
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    $\begingroup$ This is a Q&A website, thus you may ask a clear and specific question (e.g. where can I find drawing and blueprint of B737-800?) $\endgroup$ – Manu H Jan 19 at 15:44
  • $\begingroup$ Thanks for the feedback. If there are blueprints that show internal space division, then yes please! I would love to see those. $\endgroup$ – M.Krikke Jan 19 at 15:50
    $\begingroup$ I think the question is quite clear, although documents more specific than @Daniel's answer may be hard to find. A "how it's made" 3D picture with cut-away drawings of the internals may be your best source, even if you have to estimate some of the dimensions. $\endgroup$ – Ralph J Jan 19 at 20:45
  • $\begingroup$ Some of this information is in the aircraft maintenance manual (AMM) (example). $\endgroup$ – mins Jan 20 at 10:26
Check out the "Airplane characteristics for airport planning" document for the 737, espcially from page 47: http://www.boeing.com/assets/pdf/commercial/airports/acaps/737.pdf
These kind of documents are created by the airplane manufacturer and are often publically available.
