I am thinking of getting my pilot license, I would love to fly a helicopter or a small plane, but I don't know where to start. What do I need to get a pilot's license?
Things like:
  1. How much does it cost
  2. Get a cheap plane or chopper
  3. Where to take lessons
  4. Theory and practical
  5. Is there a difference which plane or helicopter I may fly, especially in size
Any info is welcome.
    $\begingroup$ Your location is quite relevant to this question, so consider adding it. $\endgroup$ Jan 14 '19 at 10:47
    $\begingroup$ Welcome to the site @HarryStylesheet! I wish you the very best in your mission, unfortunately your question is too broad for this site and therefore likely to get closed. There are many how-tos on forums and there may be questions covering parts of your question on this site already. $\endgroup$
    – GdD
    Jan 14 '19 at 10:54
  • $\begingroup$ Okay then it is all right i will find my way $\endgroup$ Jan 14 '19 at 11:06
    $\begingroup$ It's not that it is too broad, but rather than it can be expanded to a number of questions. As @AEhere stated, knowing in which country you live would influence the answers greatly. $\endgroup$ Jan 14 '19 at 11:09
    $\begingroup$ A good question on Stack Exchange is a single question that can be answered authoritatively. This means, at a minimum, that you should (a) specify where you are located, or where you plan to get your license (this matters!), and (b) ask one question at a time. It's fine to post multiple separate questions, but each question you post should contain just one question. Also, I'd expect there to be differences between helicopter and fixed wing training, so you may want each question to focus on one of those rather than both. Hope you'll get the answers you seek! $\endgroup$
    – user
    Jan 14 '19 at 13:18
Some answers:
1) How much does it cost.
Cost will vary based on numerous factors, such as your age; being older seems to take more hours than younger - different reflexes, different reactions compared to experience from other motor vehicles. At the same time, being older one can probably be able to fly more regularly, which really helps. Or perhaps not if being older one is stuck with house and car payments and saving for college, etc. For a full-up private license, a minimum of 20 hours of dual and 20 hours of solo time is needed. I started at 33, could afford twice a week, missing a lesson seemed like two steps back at times. Ended up with about 70 hours total by the checkride, and my wife ended up with similar when she got her license a couple of years later.
2) Get a cheap plane or chopper
I believe Plane will be less cost - helicopter lessons are more. Must be a maintenance thing - they do seem to just want to vibrate themselves apart! The times I have looked into it, helicopters seemed to be twice as much.
3) Where to take lessons
Someone else already answered - find an airport near you and ask around. If it becomes too impractical for you to get there on a regular basis, you may not be likely to keep doing it.
4)Theory and practical
Depending on the school, you may or may not be required to take "ground school" with them, where a lot of basics are covered, and prep for the knowledge exam and the checkride is done. Being a college grad, I took the self study path instead, and anything I couldn't figure out, or didn't understand, I brought up during flying lessons. Jeppesen.com has good study materials, as well as courses you can find at Sportys, King Schools, etc. Once you apply for the student license/medical, you will get a lot of stuff in the mail. Do that early to make sure you can pass the medical (it's very basic). Ask at the airport for recommendations on nearby Aviation Medical Examiners (AME).
5) Is there a difference which plane or helicopter I may fly, especially in size
Airplanes, you may start in a small 2-seater (I started in a Cessna 150) or a somewhat larger 4-seater (Cessna 172 is very popular), or a similar low wing plane from Piper (like a Cherokee). Helicopter, the Robinson R-22 is a popular 2-seater for starting. R-44 for 4-seats.
Which license you go for depends on your "mission". Want to take some friends up and go sightseeing without spending a fortune? Plane I suspect is more affordable. You can also look at "trade a plane" magazine to see prices on what's for sale in the used market. There are also plenty of kit planes and helicopters and gyrocopters you can build if so inclined.
There are also plenty of very light sport aircraft (LSA) planes, basic 1 and 2 seaters with limited speed and fuel capacity, not intended for more than just local flying, but longer trips would be possible with some tenacity.
