I'm currently taking aerodynmics course.In the classical thin airfoil theory. we saw that both for symmetric and non-symmetric airfoils the term $dc_l/d\alpha= 2\pi$. But in the preceding chapter, calculation of aerodynamic center, if we calculate aerodynamic center with using values of Lift and Moment about the quarter chord, there appear the following equation:
0=$\dfrac{dc_l}{d\alpha}(x_{ac}-0.25)+\dfrac{d{c_{m,c/4}}}{d\alpha}$
However, the problem is that, in the example question, the solution is like the following:
  • There are given two values of $c_l$ and $c_{m,c/4}$ for different angle of attacks.
  • $\dfrac{dc_l}{d\alpha}$ calculation is being done by applying finite difference for these two values.
Finally, I don't understand why we do not use the value of $2\pi$ directly.
Thanks for advance :)
  • $\begingroup$ You might be better off asking this on Physics.SE. $\endgroup$ – ZeroOne Jan 14 at 16:56
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
