Did the wing design on the P51D, which used a laminar airfoil, affect its maneuverability? If so, how? To what extent?
closed as too broad by Ralph J, Gerry, GdD, xxavier, SMS von der Tann Jan 7 at 21:52
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • $\begingroup$ Just to double check, this is about the airfoil, not the wing structural elements, right? $\endgroup$ – AEhere Jan 7 at 14:13
  • $\begingroup$ I wonder at the downvote; this seems legitimate at first glance, as I'd expect the stall characteristics of laminar airfoils to creep up somewhere on the edges of the flight envelope. $\endgroup$ – AEhere Jan 7 at 15:18
  • $\begingroup$ The choice of airfoil most certainly affects how an aircraft, any aircraft, flies -- how could it not? Beyond that, what sort of answer are you looking for? $\endgroup$ – Ralph J Jan 7 at 15:18
  • $\begingroup$ What my answer is no good? The stall behaviour WAS the primary negative impact of the 1st gen laminar airfoil on the Mustang's handing. $\endgroup$ – John K Jan 7 at 22:15
Yes it did because the stall behaviour of the Mustang, due to the airfoil, was very abrupt and it was much easier to get into an accelerated (high speed) stall pulling high G than it was with an airplane such as a P-38, which had wonderfully benign stall behaviour and could be manhandled all over the sky in relative safety. At the beginning of a trip in the P-51 this was made worse by the aft fuel tank's effects on CofG which made the stick forces very light so you wanted to avoid radical maneuvering until you burned off the fuselage tank fuel.
The later versions of the P-38 with hydraulic ailerons and dive flaps were just about the best propeller driven aircraft in the sky in 1944, because at high speed they could roll as fast as SE fighters and had the benefits of crazy rate of climb and no engine torque effects, on top of the very gentle stall behaviour. One reason the Mustang dominated, even though the Lightning's technical bugs were worked out by that time, was the P-51's performance and range was great AND it was only about 2/3rds the unit cost of a P-38.
