Various websites have stated that during the 737-MAX crash in Indonesia, the pilots could not pitch up because of a faulty AOA sensor pitching plane down.
Stabilizer has a rear fulcrum and front jack screw. Elevator, positioned by yoke, is hinged to stabilizer. If yoke is pulled back, elevator moves up. Then stabilizer must move down, either automatically or manually, to remove yoke loading. However, if yoke is at full back extreme, why doesn’t this force the stabilizer down directly so that pilot always has total control of pitch without checking flight manual or pushing switches?
The yoke does move the elevators, whereas the trim moves the horizontal stabilizer. The stabilizer is much larger than the elevators, and therefore is more effective than the elevator at extreme angles. Even with full backpressure, the nose would continue to pitch down.
Nonetheless, all 737NGs/MAXs have trim cutout switches, 1 for the autopilot and 1 for the normal electric trim. Using these would immediately disable the electric trim. These are generally part of a standard trim runaway situation, but the crew did not recognize the situation and failed to use them.
  • $\begingroup$ +1 Good answer but IMO does not explain "why doesn't the yoke also move the elevator at yoke extremes (full forward and full back) so that pilots always have pitch control?". That's a good question IMO. $\endgroup$ – summerrain Jan 7 at 1:54
    $\begingroup$ Because the yoke DOES control the elevator. The basis of the question is incorrect, the yoke does NOT control the Trim. In fact, the 737 does NOT have Trim Tabs, it has Servo Tabs for when the Flight Controls are in Mechanical Mode. $\endgroup$ – RAC Jan 7 at 9:51
    $\begingroup$ Note that the previous crew did use the switches. The condition already existed on PK-LQP during the flight (JT-43) preceding the accident one and the crew cut out the trim (shortly after take-off) and completed the flight. They reported all the various symptoms they had to maintenance, but the troubleshooting instructions failed to mention the possibility of them being caused by bad AoA probes, so maintenance didn't check it. $\endgroup$ – Jan Hudec Jan 8 at 20:47
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
