Which are the advantages of using a ramjet compared to a rocket engine in an air-to-surface missile? I suppose the cost rises a lot, so why do some countries use ramjets as a way of propelling ASM missiles?
$\begingroup$ According to Wikipedia, only the Soviets used ramjets on a2s missles, because of the combination of long range and high speed. $\endgroup$– abelenkyDec 31, 2018 at 3:34
$\begingroup$ the French ASMP also uses a ramjet (en.wikipedia.org/wiki/Air-Sol_Moyenne_Port%C3%A9e). $\endgroup$– HobbesMay 15, 2019 at 8:55
A rocket-powered missile carries both fuel and oxidiser and oxidiser is the heavier part. For example a gram of jet fuel needs almost 3.4 grams of oxygen to fully burn! Increasing the fuel load requires also increasing the power, which means even more fuel and this limits the practical range of a missile.
Ramjets are air-breathing, so they don't need to carry the oxidiser, which means the same amount of fuel gives them significantly longer range. Plus the other constituents of air, and extra air, that get pulled along and heated in the engine add to the available reaction mass, further increasing the propulsive efficiency.
Longer range means the aircraft can fire the missile further away and avoid coming into range of the defenses placed around the target, which might make difference between being able to attack a heavily defended target and not, so it is worth the expense to have some in stock.
Also note that ramjet is only more complicated, and expensive, than a solid-fuel rocket motor. Compared to liquid-fuel rocket it is simpler, because it only needs easy-to-handle kerosene while liquid-fuel rockets either need liquid oxygen, or nasty stuff like peroxide or hydrazine. It is also simpler compared to a full turbofan or turbojet (a small solid rocket booster is usually used to get it up to speed).
$\begingroup$ Very interesting and well-reasoned answer. I wonder why, if ramjet-propelled missiles have so many advantages, are they so rare... $\endgroup$– xxavierMay 15, 2019 at 6:46
$\begingroup$ That's because they also have disadvantages. Drag from the intakes, extra complexity, extra handling (fueling the missile before flight), for example. $\endgroup$– HobbesMay 15, 2019 at 9:17
$\begingroup$ And lower thrust-to-weight ratio. Unless your missile is meant for very long range, the high TWR of a rocket results in lower total system mass for given delta-V than the lighter fuel of a ramjet. $\endgroup$– TheracJul 12, 2019 at 19:46
Jan Hudec’s answer here is pretty good, but the I’d add that it’s more than just oxidizer, it’s the idea with a ramjet that:
1) You can use the air from the atmosphere itself as a working mass. It’s also the same reason airliners and other airplanes don’t make use of rocket engines for propulsion. As opposed to a rocket engine which requires the vehicle to pack all the mass used to create thrust from, in a ramjet all that’s needed is the fuel which reacts with oxygen in the atmosphere to heat the air moving through the engine core. The upshot is that the aircraft has much greater range that it would with a rocket engine, which can only burn for a brief time before going into unpowered ballistic flight and quickly decelerating due to atmospheric drag.
2) Ramjets have no moving parts which make them simple, reliable and light weight as opposed to jet engines or liquid fueled rocket engines.
3) Ramjets are safer than liquid fueled rockets due to not carrying an oxidizer aboard.
4) Ramjets offer good performance at supersonic speeds ie Mach 2 to Mach 5 range, giving the missile a lot of smash or kinetic energy to the target and reducing an enemy’s ability to evade the missile.
The downside to Ramjets is that they won’t work at slower speeds. This requires another type of propulsion system like a solid fuel rocket booster to accelerate the missile up to its cruise speed before the Ramjet can light and continue the flight.
$\begingroup$ Would be very interesting to compare top speeds "down on the deck". The SR-71 was essentially a ram jet at top end, but at very high altitude. $\endgroup$ May 15, 2019 at 7:18
$\begingroup$ You can actually make solide fuel ramjets. There are even tricks to make it work as a solid fuel rocket initially until the burning of the grain unclog the air entry, at which point it switches to ramjet mode. This allows to have "built-in" boost stage. This wouldn't be worth it on a reusable engine, but is perfect for a missile. $\endgroup$– EthJan 28, 2021 at 17:19
Simplicity of propulsion translates to cost savings, but there are tradeoffs in using a ramjet in a missile. The reason most aircraft-carried missiles do not use ramjet engines is because such a missile has to be accelerated to a sufficient speed for the engine to begin producing thrust.
What this means is that such a missile can only be carried by aircraft that can fly at mach 0.5 or above, or they have to be equipped with some other means of propulsion to accelerate the missile so the ramjet can start operating. It is much simpler to equip it with a rocket or turbine engine, depending on the requirements of the design.
It's a slightly odd question, as for the most part a ramjet isn't an alternative to a rocket engine for an ASM, but an alternative to a turbojet or turbofan engine.
On the whole, rockets are normally used in short-range weapons (typically on semi-ballistic trajectories), whereas cruise missiles (utilising aerodynamic lift for flight) use various types of jets for propulsion. A few older cruise missiles (particularly in the anti-ship arena) use rockets, such as the Styx/Silkworm missiles and the older Exocets.
For a long-range cruise missile ramjet propulsion provides the cost/benefit split versus other jets as you'd expect - more fuel means a larger missile, but a higher speed makes interception harder. Flying faster also makes for more difficult guidance (read expense), and the extra heat (along with possibly having to fly higher) negates some of the interception advantages. There's a distinct East-West split on whether this is worthwhile - Soviet/Russian weapons tend towards large and very fast (using ramjets), whereas Western missiles tend to be both smaller and cheaper, and avoid interception by means of stealth and increased numbers launched.
Speed, size and cost. Rockets engines are smaller and faster then any air breathing engine. In retrospect this would be ok engine for a smart missile that can track slower fighter aircraft like a fast drone.
The advantage is that your air to surface missile can be supersonic and run on cheap gasoline. The Air Force BOMARC was surface to air ram jet powered, capable of speeds greater than Mach 2. They were accelerated to operational speed with simple solid fuel boosters. These could easily be converted to air to surface, launched from an aircraft travelling at sufficient speed.
But alas, surface to air missiles are much faster, and an incoming supersonic, although much faster than a slow stealth, will be detected much sooner.
However ramjets may make a comeback if they are applied to supersonic cargo or passenger aircraft. Marquardt, if they are still around, might be the ones to call.
