This extreme sweptback delta was built to test the Concorde wing at low speeds, sources say it had a biconv 6% airfoil, but I failed in finding data about it.
Did you see what Wikipedia had for it, and the book it came from?
Specifications (HP.115) Data from X-Planes and Prototypes: From Nazi Secret Weapons to the Warplanes of the Future [Winchester 2005, p. 134]
General characteristics
Crew: one
Length: 50 ft 4 in (15.33 m)
Wingspan: 20 ft (6.1 m)
Height: 12 ft 9 in (3.9 m)
Wing area: 432 ft² (40.1 m²)
Airfoil: Bicon 6%
Empty weight: 3,680 lb (1,670 kg)
Useful load: (Fuel) 1,175 lb (533 kg)
Loaded weight: 5,050 lb (2,291 kg)
Powerplant: 1 × Bristol Siddeley Viper BSV.9 turbojet, 1,900 lbf static (8.455 kN) Performance
Maximum speed: 248 mph (399 km/h)
Endurance: 40 minutes
This paper goes into calculations on biconvex airfoil as well, interesting reading https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19930085007.pdf
  • $\begingroup$ Thanks for the good NACA 252 paper, but even with this info, I'm not able yet of drawing a: 'Bicon 6%' airfoil. $\endgroup$ – Urquiola Dec 31 '18 at 15:30
  • $\begingroup$ Time to check the libraries in your area and see if any have the book: Data from X-Planes and Prototypes: From Nazi Secret Weapons to the Warplanes of the Future [Winchester 2005, p. 134] $\endgroup$ – CrossRoads Dec 31 '18 at 15:45
  • $\begingroup$ To CrossRoads: the excellent book: 'X-planes and prototypes' just arrived. No mention of an airfoil in the two pages about Handley Page HP.115. I insist: this HP.115 is almost identical to the Roy Scroggs': 'Flying Dart', The last laugh!', Pat US3051415,1932, including many interesting features, as a low dorsal fin, matching XXI century Chinese research (Xuanshi Meng et al), extended elevons ('Tailess Aircraft', K Nickel&M Wohlfahrt),... $\endgroup$ – Urquiola Jan 11 '19 at 11:52
