I was a passenger in an A340 during a famous storm 65kts gusting 95kts. Resulted in a go around, but the plane sunk quite fast several times. Is this rare? Are there limits to headwind component? The captain said we experienced extreme wind shear, is that an official grade? Checked the metar for the kts.
  • $\begingroup$ Hi Tapani, welcome to aviation.SE. Please be aware that we prefer to have only one question per post, and you currently have 4-5 (depending on how you count). Can you please focus your post on one single question? Otherwise it risks being closed as too broad. thank you. $\endgroup$
    – Federico
    Commented Dec 18, 2018 at 8:54
  • $\begingroup$ Some specifics would be nice: where and when this happened? $\endgroup$
    – Jpe61
    Commented May 12, 2020 at 8:51
Wind shear is also gusts, but the difference is that wind shear involves changes in speed and direction, where gusts are generally in the same direction. 65kt gusting 95kt is a very rare situation that no airline captain would want to tackle unless the situation demands it (low fuel, some other emergency) and the winds are straight as an arrow down the runway. You could land the airplane that way, but a 95 kt gust can certainly lift a wing or cause weathervaning when the aircraft is taxiing off the runway.
Now, if the report is for wind shear gusting that high, it would be crazy to try to land an A340 (or any other aircraft for that matter) unless the pilot had zero other choices (or just didn't know that there was low-altitude wind shear). The max crosswind component for landing on an A340 is around 37 kts.
From what you are describing, it seems they experienced wind shear, and not just gusts.
  • $\begingroup$ Isn't wind shear defined as an unusually rapid change in wind speed / direction as a function of altitude? $\endgroup$ Commented May 17, 2019 at 23:37
  • $\begingroup$ @pericynthion Wind shear can be measured horizontally or vertically but that is not a requirement to call it such. $\endgroup$ Commented May 19, 2019 at 11:45
