NOTICE: The modern lift equation and the lift equation used by the Wright brothers in 1900 are slightly different. The lift coefficient of the modern equation is referenced to the dynamic pressure of the flow, while the lift coefficient of the earlier times was referenced to the drag of an equivalent flat plate. So the value of these two coefficients would be different even for the same wing and the same set of flow conditions.
Above is a quote from a NASA website (emphasis mine). It's new for me that the Wright brothers applied different calculations to their plane. So, what was the equation used by the two brothers?
