Ducted Fan Efficiency -HoveyC F Johnson DF fuselageCF Johnson Ducted Fan fuselage aAirplane Wing and FuselageAircraft ConstructionRoy Scroggs, a tailor, patented in 1917, US1250033, and in 1932 US1848578, a Delta Wing plan form machine 'Flying Dart', flight tested
with an OX-5 engine, they say anything would fit an OX-5 powered airplane, as in Besler Steam Airplane, it had same Leading Edge swept, 60º, as Handley Page HP 115 of 1961, that tested the Concorde wing (
Roy Scroggs Flying Dart
I wonder what the power requirements and performance would be of an Ultralight Airplane with a wing span of 250 cm, maximum width allowed on the road, and a total weight less than 299 kg.
First, thank you for unearthing this unorthodox design!
However, it shows that paper airplanes don't scale well. Nevertheless, it follows the same laws of physics, so the same equations should apply for a quick performance evaluation. What have we got?
  1. A flat plate airfoil. Maximum lift coefficient will be between 0.7 and 0.8, so minimum speed at a given wing loading will be quite high.
  2. A sweptback delta wing of low aspect ratio, so the lift curve slope will be low. For the same lift coefficient it needs much more angle of attack than a regular airplane. Since upper side flow is separated, airfoil drag will grow with the square of the angle of attack, and the low lift curve slope ensures that drag will be needlessly high.
  3. A big fuselage with a lot of wetted surface area.
  4. A massive separation area at the back which will produce a lot of drag without any benefit, except for improved directional stability.
Let's start with induced drag. The low aspect ratio ensures a nearly elliptic lift distribution, and lifting 300 kg with 2.5 m of wing will create $$D_i = \frac{2\cdot(m\cdot g)^2}{\rho\cdot v^2\cdot\pi\cdot b^2} = \frac{180000\cdot g^2}{1.225\cdot v^2\cdot3.14159\cdot 6.25} = \left(\frac{g}{v}\right)^2\cdot 7483\;N$$ At 20 m/s flight speed this will equal 3,600 N of drag and at 40 m/s flight speed a quarter of that (900 N). Multiply by speed to get the power needed to overcome just induced drag: 36 kW at 20 m/s and 18 kW at 40 m/s.
But what speed is achievable? We need to guess the wing area in order to find the stall speed. I assume 4 m chord and 1 m span at the leading edge, so the wing area is 7 m². Using a maximum lift coefficient of 0.75, this means you cannot fly slower than 30.24 m/s. Whoa! That is 58.8 kts or just below the 61 kts limit for the old FAR 23.
Let's add some safety margin and continue with 40 m/s flight speed, which corresponds to a lift coefficient of 0.43. Now to the angle of attack - this requires to know the lift curve slope. As a slender body it will be slightly below $\pi\cdot\frac{AR}{2}$, and with an aspect ratio $AR$ of below 1 this is maybe 2.2 per radian or 0.04 per degree. At $c_L$ = 0.43 this is 11°. Multiply the weight with the sine of 11° and you get the cost for flying a fully separated top wing: 506 N. Dragging this through the air at 40 m/s needs another 20.2 kW.
Now to the wetted surface: The vertical surfaces add maybe another 4 - 5 m² to the 14 m² of the wing. The Reynolds number is 11$\cdot 10^6$, so the friction drag coefficient is as low as 0.003 if the surface is smooth. Since the upper wing shows separated flow, I will continue with 15 m² surface area. At 40 m/s this equates to 44.1 N of drag, needing 1.76 kw of power.
The fixed and unfaired landing gear will be another source of drag; here I simply double the friction drag in order to account for it, too. I expect that a detailed drag analysis will not change the result substantially.
Your idea of filling the separation area with a ducted fan is probably costing even more performance. Please consider that now you have a high-speed stream of air flowing through a duct running along the length of the fuselage. Better to narrow the fuselage in the rear half so it ends in a vertical rudder.
If we now assume that you avoid any boattail drag this way, flying straight and level at 40 m/s will need a total of 42 kW. Add 50% for manoeuvring and climbing (those extra 21 kW translate to a climb rate of more than 6 m/s - looks OK) and a propeller efficiency of maybe 75% (look at this answer - that could be as low as 60% in reality!), and you end up with an engine requirement of 84 kW or 112.6 HP. It looks like you need a Rotax 914 or similar engine, the mass of which will eat up one third of your budget.
  • $\begingroup$ Thanks for your excellent and kind help. You can watch in YouTube video that the Scroggs, man carrying machine, actually went airborne, 3 mt above ground, it's described in 'Aerofiles'. Goal is 255 cm span, 2 meters and a half, the maximum width allowed for a road vehicle, you know main issue in 'Flying car' is passive road safety rules; SAE book: 'Vehicle compatibility in Automobile crashes', depicts situation. Idea is making first an 80 cm span Aeromodel, with a ducted fan inside, perhaps with an Space Shuttle Wing Plan. 299 kg come from me, 135 kg, plus engine, structure, fuel,... $\endgroup$ – Urquiola Dec 19 '18 at 12:31
  • $\begingroup$ Instead of the open, drag generating end in the Scroggs machine, a Ducted Fan blowing rearwards inside fuselage, the engine cooling and exhaust heat added to increase thrust will reduce problem stated in point 4. The wingtips acting as ailerons,as in Hoffman design, see 'Wingless wonders', YouTube, elevons in the rear straight trailing side of wing, plus a vertical Fin-Rudder upside providing control, even if I'd like an 'Inverted Vee', or 'A' type of 'tail unit, inducing roll in the right sense at turns. $\endgroup$ – Urquiola Dec 19 '18 at 13:20
  • $\begingroup$ @Urquiola thanks for showing this design. Inspired by record setting "Paper Airplane Guy" and the 225 foot indoor throw, the 60 degree HP 115 was my first choice for scratch builds too! However, deltas do not provide nearly as much lift as straight wings, hence 112 HP requirement! Notice the Aeronca C3 flew quite well with 36 HP at around 1000 lbs. You may wish to check out high wing or bipe ultra lights. $\endgroup$ – Robert DiGiovanni Dec 21 '18 at 3:31
  • $\begingroup$ Thanks. Your comments about in-Fuselage Ducted Fan propulsion seem confirmed in the Stipa-Caproni results. I attach documents about a similar US design, and DF efficicay figures from the Hovey booklet, not that bad. They were preparing an electric DF version of a MiG fighter in Russia. Salut + $\endgroup$ – Urquiola Dec 22 '18 at 9:54
  • $\begingroup$ With the Space Shuttle Wing Plan and the fixed span (regulatory requirement) of 2.5 meters, the overall Wing length would be 6,1 meters; a Wing Area around 7 m 2. What about a Wankel RCE? Please see www.rotaryeng.net $\endgroup$ – Urquiola Dec 22 '18 at 10:08
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
