According to Wikipedia, only single-engine aircraft with an MTOW no greater than 12500 pounds are required to demonstrate the ability to recover from a spin, and not large or multi-engine aircraft. This seems backwards to me, as it would seem to be far more critical for an airliner with potentially hundreds of people on board to be able to successfully escape from a spin than it would be for a small GA aircraft where only the pilot's life is at stake, and not anyone else's.
Can someone explain this seeming contradiction?
    $\begingroup$ Little single engine airplanes have stall spin accidents maneuvering to land all the time because of the way they are used. When is the last time an airliner got into a spin on approach? You have to cater to scenarios with a certain level of probability, not every possible thing that could ever happen. $\endgroup$
    Dec 11, 2018 at 4:56
1. Spins are less frequent on large aircraft
  • They are less maneuverable
  • They are flown by more experienced pilots
  • They have more protection systems (e.g. flight envelope protection, yaw damper) to avoid uncontrolled flight
2. Spins may cause structural damage on large aircraft
The larger the aircraft, the lower its tolerance to stress. While one can quite comfortably spin a Cessna or Cherokee, attempt one on a Boeing 777 and things will break. Gear doors, the bolts holding the vertical stabilizer as well as cabin accessories are not designed to handle stress in that direction, not to mention engine flame-out.
3. Spins may not be recoverable
As discussed in this question.
