On a cross-country trip, is it normal to terminate FF at each stop and reacquire it (potentially just a few minutes later) for the next leg, or would ATC prefer that you advise them it'll be a short stop and maybe let you keep the code to reduce their hassle later?
    $\begingroup$ Are you asking about landing at untowered airports? I've never had flight following continue through a stop, they always cancelled it once I said "airfield in sight" (which results in them saying "Roger N12345, radar services terminated, frequency change approved") and from then out you are not getting flight following anymore... $\endgroup$
    – Ron Beyer
    Dec 7, 2018 at 16:19
  • $\begingroup$ Yes, I was thinking of untowered airports, specifically for a student solo cross-country flight, where you're mandated to land twice but expect to be back in the air within a few minutes each time. $\endgroup$
    – StephenS
    Dec 7, 2018 at 16:30
  • $\begingroup$ For my students, I have them leave the plane at each stop, get fuel, get a WX briefing, preflight again, and file a new flight plan. It gives them better practice at those things, which while they are not specifically flying, they are related. $\endgroup$
    – mongo
    Dec 8, 2018 at 16:08
As @RonBeyer notes in the comments Flight Following will drop you when you land. Generally (also as Ron notes) they will ask you to call the "field in sight". It really depends on where you are and what kind of air space you are in. Where I fly in the Northeast they typically drop you when you have the field in sight but its hard to stray to far from a heavily controlled area if you are flying between DC and Boston but it may be different elsewhere.
Keep in mind that you will need to get off the frequency so you can make your CTAF announcements anyway. It may be a good idea to keep the controller as a listen only channel on COM2 if you are equipped for such in your aircraft.
Assigning you a code is not really a hassle for them so you don't need to worry. In a busy airspace ATC may want you out so they can handle IFR traffic. Remember flight following is "load dependent" so you might not always get it and you can be dropped out at any time.
When on your student XC's its always a good idea to preface one of your initial calls with "N123AB Student Pilot requesting flight following". ATC is there to help you and noting you are a student pilot may help you so they don't expect professional pilot level flying and radio chatter from you.
  • $\begingroup$ Thanks. When I did my student solo xc long ago, my CFI was anti-GPS and anti-FF (dead reckoning only), so there was a lot I missed, and then I quit flying for over a decade. The regulations haven't changed much, but I've got a lot of practical details to catch up on. $\endgroup$
    – StephenS
    Dec 7, 2018 at 17:47
    $\begingroup$ @Stephen Sprunk, perhaps you do not think so, but your CFI did you a great service. $\endgroup$
    – mongo
    Dec 7, 2018 at 20:06
  • $\begingroup$ If ATC is asking you to report the field in sight when you're VFR they're working too hard... $\endgroup$
    – randomhead
    Feb 1, 2021 at 23:11
Flight Following is intended to track your flight from time of activation to reaching your destination. It provides for ATC services which include traffic advisories, and emergency services. It is expected to terminate at point of landing.
That said, depending upon workload, some TRACONs will provide flight following which continues through approaches or even touch and goes at an intermediate airport. However this is a workload and controller preference. And it is not intended to support full stop landings, or passenger changes. If you routinely make stops, you might let the controller know you will be back in 3 to 5 minutes, and they may keep your ticket alive, but that is only likely if they are not very busy at that time.
Flight following in Canada is called an en route radar service, which perhaps better describes flight following. In the US, years ago, a request was customarily made for "radar services" which were essentially that of flight following.
In summary, flight following is not intended to carry over "flight to flight" where flights are normally terminated by landings. Think of it as radar services, not necessarily a flight plan with SAR backup.
