Let's assume we lose left engine on a twin-engine aircraft during a straight and level flight without a side slip. In order to compensate yawing moment to the left from the right engine we deflect the rudder to the right (picture 12.21), however there appears an unbalanced force to the left behind the CG (rudder force). It is said (at least in the book I study about principles of flight) that there are two ways to balance the side force from the rudder: with wings level (picture 12.23) and by banking slightly towards the live engine. At first I would like to consider the first method. It states that yawing to the live engine gives a side slip force on the keel surfaces behind CG opposite to the rudder force. That's fine, however if it acts not through the CG (what is the case in the picture 12.23) there should as well appear a moment from that force which would again yaw the aircraft to the left? Am i missing something?
closed as unclear what you're asking by fooot, xxavier, Sean, Ralph J, anshabhi Dec 7 '18 at 13:44
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    $\begingroup$ I find your question a little confusing. First, all moments will act "through" the cog, that is, the cog will be the axis along which the force will try to rotate the plane. $\endgroup$ – TomMcW Dec 6 '18 at 20:56
Julious, Figure 12.21 is the one you should be looking at. Here the rudder yaw torque balances the asymmetric thrust torque, keeping the plane straight into the direction of flight. Minimizing drag is very important to maintain airspeed with an engine out.
Figure 12.23 appears to represent a case where too much rudder as applied, creating a side slip. This is understandably confusing, but common sense will tell you the directional stability of the aircraft will try to bring it back into line with the direction of flight. That is what "side force from side slip" is.
Remember, directional stability is there whether you have 0, 1, or 2 engines out! This is a part of the aerodynamic design of your plane so it flies straight, unless you use the ailerons, elevator, or rudder to tell it not to.
I don't know whether the side force will create a left yawing moment or not. (The picture seems to suggest that it will.) But in any case, if it does create left yawing moment, you can just add more right rudder to counteract it. There's going to be a point where the yawing moment from the rudder cancels out the yawing moment from everything else.
  • $\begingroup$ Tanner Swett, but if add more right rudder in order to counteract yawing moment you will add rudder force to the left as well which will no longer counteract side force from sideslip. $\endgroup$ – Julious Dec 7 '18 at 9:07
  • $\begingroup$ @Julious But that'll just result in a different flight path. There's always going to be some combination of aileron and rudder which results in the wings being level and the flight path being straight (unless you hit the limits of one control or the other). $\endgroup$ – Terran Swett Dec 7 '18 at 15:38
