I have problems whit the level in each tank after a flight of 3 hours. I usually use the right tank the first hour and then I change to the opposite, but when I check the level after that the rigt tank seems as if have not burned the fuel.
  • $\begingroup$ Is your right tank fuel gauge working? $\endgroup$ – Dan Pichelman Dec 5 '18 at 17:03
  • $\begingroup$ yes, it is working my friend. $\endgroup$ – Teddy Jose Ruiz Romero Dec 5 '18 at 17:23
