It seems that the blades on the V22 or AW609 would have to be heavier than conventional helicopter rotor blades since they have to be substantially stiffer when in fixed-wing mode. Normal helicopter blades would flap beyond acceptable levels when exposed to such high forward airspeed. It also appears that since tiltrotor disc loading is much higher, conventional thin helicopter blades would sag excessively.
So, how much do the blades actually weigh?
