29
So the other day as I was flying, I started to wonder:
cloud flying
All pilots should be familiar with basic VFR cloud clearance requirements in 14 CFR 91.155 (and if not, then go study now!). When flying piston airplanes, we probably spend most of our time in the Class E below 10,000 ft. arena:
Class E < 10,000
This is great and all, but how can we actually determine how far away we are (especially vertically)?
I thought about using a sextant and some "simple math":
sextant
sample math
Unfortunately, I need to know my actual distance TO the cloud as well as my angle... A quick Google search found one of these, but I'm not so sure how it will work with a cloud:
Range Finder
In all seriousness though, how can we stay legal and safe when operating VFR in the vicinity of clouds?
19
The answer, as best I can discern it from my training & my own experience, is "You can't!" -- every instructor I've flown with has said that cloud clearances are the most inadvertently-busted regulation, even when pilots are doing their best to obey the requirements.
Our eyes and brain are really good at judging distance relative to landmarks and objects of known size (that's how we can tell we're on a "3 mile final" or "8 miles out"), but without known references our ability to estimate distance quickly falls apart, and there simply aren't that many useful landmarks in the sky.
Judging lateral distance to clouds is, at least in my experience, generally easier than vertical distance - as long as you're a fair distance away from the cloud anyway.
You can roughly estimate the ground position of a cloud pretty easily (and if you can't you can always use its shadow and be pretty close). You can also usually find features on the ground of known size (runways, for example: You can get the length of the longest runway at a field from your handy VFR sectional), and figure out how many of those are between you and the cloud's ground position.
Also if you're doing this whole pilotage-and-navigation thing right you know where you are on the chart, and you can visually estimate the ground position of a cloud pretty easily (again if all else fails use its shadow and you'll be close). Break out your plotter and you can figure out how many miles away you are from the cloud (but inside about 3 miles this is going to get pretty difficult, and with your head in the cockpit mucking about with the chart and plotter you may wind up inside the cloud by the time you're done working up your estimate!).
A final close-in technique for clouds at your altitude is to use your wing. You know your aircraft's wingspan, and you can also say that roughly half that value is the length of one wing. Figure out how many "wings away" the cloud is, and do the math -- of course if you're at a distance where you can do that kind of visual estimation you're likely to be close to the cloud clearance limits.
Judging vertical distance is harder. The usual advice if you're below the clouds is to get the cloud heights from a local airports ATIS or AWOS and use that as a guide. If you're above the clouds PIREPs for cloud tops serve the same purpose.
Visually if you're above the cloud the same skills you use to judge your height above a runway will work. The catch is those skills really only work when you're within about 1000 to 2000 feet (i.e. "By the time you can really judge the distance you may already be too close!").
Coming up from below a cloud you're basically relying on judging your closing speed to an object of unknown / nebulous size: As you approach the cloud it's going to get bigger, but you don't really know how big it's going to get before you wind up inside it.
As a final visual cue in any direction, remember that clouds aren't clearly-defined boundaries - Often you'll see little wispy streaks of cloud around you as you're getting closer to the cloud you're trying to avoid (particularly when approaching from below). This is a pretty definitive indication that you're probably closer to the cloud than you should be, and you should start heading away from the cloud before you wind up inside it.
I think the best bottom-line practical advice I've ever gotten on cloud clearances, loosely paraphrased from a couple of the local CFIs: "Just stay way the heck away from clouds until you're instrument rated and on an IFR flight plan." and "If you think you might be too close to a cloud, get further away!" -- the latter probably being what the FAA is getting at with their statutory distance requirements.
While distances are hard for many people to estimate, time is much easier for many people to estimate. Pull out your trusty E6B, and work out the distance in terms of seconds.
For example, at a cruising speed of 110Kts (typical for many small GA student planes),
  • 3 Miles is 1 minute 30 seconds
  • 2000 feet is 10 seconds.
So if you cannot see where you'll be in 1:30, visibility is too low.
If you can fly to a cloud in less than 10 seconds, you're too close.
Edit
Flying Magazine essentially said the same thing in "Judging VFR Cloud Distances"
  • $\begingroup$ Unfortunately, it is also really hard to estimate where I will be in relation to the cloud in 10 seconds as well. Or how can I tell whether or not a cloud is 500 feet above me? $\endgroup$
    – Lnafziger
    Jan 4, 2014 at 18:58
    $\begingroup$ Yes, but will I be there in 10 seconds or 30 seconds or 5 seconds? Sometimes (especially in a widespread overcast area) it is nearly impossible to tell how far away you are because you have no visual reference to determine your relative position. $\endgroup$
    – Lnafziger
    Jan 4, 2014 at 19:19
    $\begingroup$ Also, I agree that "if I can climb into a cloud in less than 30 seconds" that I am too close. However, without actually doing it, I am still trying to visually estimate the distance. This means nothing. $\endgroup$
    – Lnafziger
    Jan 4, 2014 at 19:20
    $\begingroup$ One of the biggest challenges is that clouds are often very hazy. Gauging depth is really hard. $\endgroup$
    – egid
    Jan 4, 2014 at 20:02
    $\begingroup$ Lastly, this regulation is there to keep you safe. Just because the FAA can't see you doesn't mean that it's safe to skim the clouds. When an IFR flight pops out of the cloud head on right in front of you, it is a problem regardless. $\endgroup$
    – Lnafziger
    Jan 5, 2014 at 4:25
It's a difficult skill to acquire. Think of the cloud clearance requirements as a guideline. Do your level best to comply with them but know that there is really no simple way to judge your true distance from a cloud.
It's a see-and-avoid world for the VFR pilot. The cloud clearance requirements are virtually impossible to enforce and the visibility mins are only slightly less difficult! All the feds are asking for is for VFR pilot to remain reasonably far away from clouds given the regime in which the plane is operating. Planes moving quickly require more distance from clouds in order to see-and-avoid other planes.
In Class B and in G/day below 10k, just stay of of clouds. You can't be deviating a mile out of the way for a cloud in Class B...you'd really screw up ATC's plan. All the little and slow planes fly in Class G during the day and under 10,000'...so just stay clear of clouds.
Above 10,000'? Stay a mile away. There are some fast planes up there and they need room to react to a possible collision.
Everywhere else? Three miles is sufficient. Mooneys, Bonanzas, Lancair 320/360...they're pretty fast but really only need about half a mile to avoid a collision.
