22
I´m now reading Bob Gardner’s book “Say again, please” and there is this instruction on page 54:
Do not turn the transponder function switch to STBY while changing codes.
What is the reason for this? I’m a PPL student and my instructor told me the opposite.
25
The FAA started advocating not selecting standby for code changes after it was found that more often than one would expect, the transponder doesn't always come back on after standby. Seems they uncovered a number of switch failures.
I figure that someone decided that for TCAS it was better to have a transponder squawking any code than not squawking. But that is my own conjecture.
So for quite a few years the guidance has been to not turn to standby when selecting codes.
I have had the folks at Flight Safety lecture me after sim sessions, with pretty much the same story.
So I now teach students to just switch the codes, and not standby the transponder. And I suggest caution when dialing through "7xxx" although controllers I have talked to say it's not a big deal.
So the idea is to keep the transponder squawking, even though numbers are being changed. There is continuity in that they will continue to have returns while you are playing with the knobs. And if you ever have a switch failure, it will likely be on the ground.
Addendum: Also, with ADS-B, one is supposed to keep the transponder on at all times, when on the airport surface in a movement area. So I can see that the philosophy of managing the standby position will continue to change.
Also note that Bob Gardner's book was from the mid-1990's and things change. Both the transponder technology, the technology, such as ADS-B, TCAS (which also relies on transponders, as well as processing algorithms, which decide how to display transitioning codes.
  • 9
    $\begingroup$ Also, it is probably more likely for it to be "pilot error" than "switch failure" when the transponder doesn't come back on after setting the code.... $\endgroup$
    – Lnafziger
    Dec 2, 2018 at 23:31
  • 10
    $\begingroup$ Modern electronically controlled transponders have a delay that waits until a few seconds after dialing stops before committing the change. And a lot of them are keypad entry now, which avoids the problem too. $\endgroup$
    – user71659
    Dec 2, 2018 at 23:42
    $\begingroup$ For a while I would fly a plane daily which would not do the 0400 bit, and of course the local TRACON assigned 0400 bit codes. The unit would go to the shop, get certified and then the switch(i assume) would get spotty. I would negotiate another code with ATC. The only people who were really annoyed were the NYC TRACON folks. Then again, at one time, I flew equipment which had two digit transponders. Yep, 12 for VFR. $\endgroup$
    – mongo
    Dec 3, 2018 at 1:19
    $\begingroup$ Good answer. I'd like to add that the transponder interrogation rate for terminal and enroute radars is quite low (5-10 seconds). As such, if you make the code change in less than 5 seconds, the radar will receive at most one, and quite possibly zero, transient codes. I don't suggest rushing through the code change, but it's worth knowing that ATC is not seeing every single transient code you cycle through as you're twisting the knobs. $\endgroup$
    – TypeIA
    Dec 3, 2018 at 16:29
    $\begingroup$ @TypeIA Also, ATC will be very aware of the fact that they've just assigned you a new code and are expecting to see it change. Other than emergencies, it should never be a surprise to ATC when your transponder code changes. $\endgroup$
    – J...
    Dec 3, 2018 at 16:32
10
The AIM implies that you should leave the transponder on ALT when changing codes—since if you are in standby you won’t be transmitting:
4−1−20. Transponder Operation
e. Code Changes
  1. When making routine code changes, pilots should avoid inadvertent selection of Codes 7500, 7600 or 7700 thereby causing momentary false alarms at automated ground facilities. For example, when switching from Code 2700 to Code 7200, switch first to 2200 then to 7200, NOT to 7700 and then 7200. This procedure applies to nondiscrete Code 7500 and all discrete codes in the 7600 and 7700 series (i.e., 7600−7677, 7700−7777) which will trigger special indicators in automated facilities. Only nondiscrete Code 7500 will be decoded as the hijack code.
