There is increasing talk about employing passenger-carrying multicopters ("taxi drones") to extend urban mobility into the third dimension. These aircraft will have MTOMs in the range of several hundred kgs.
In case this catches on on a larger scale, airspace use will increase considerably compared to the current occasional helicopter and sight-seeing flight.
For safety reasons, presumably a certain minimum vertical separation will be required due to the downwash from the rotors.
Is there any information available about the current thinking on required minimum vertical separation between manned/passenger-carrying multicopters? Also, will there be any difference for this requirement between hovering and cruise flight modes?
