Hoping someone can help me in understand who is who when using a aviation radio. eg: "Delta Delta, Tac" I understand some of them but am still quite unsure as to who is a sierra, whiskey, alpha etc. hoping someone can help a newbie out
1$\begingroup$ Can you quote a specific conversation? The same phrase can mean different things in different contexts. For example, "Delta" may refer to a taxiway, an ATIS update, an Airspace or part of a callsign. $\endgroup$– abelenkyNov 23, 2018 at 2:37
$\begingroup$ You should start by learning about the phonetic alphabet $\endgroup$– BenNov 23, 2018 at 6:42
1 Answer
Delta, ta[ngo], sierra, whiskey, alpha, etc... are all letters in the ICAO phonetic alphabet, which is a system used to speak letters in a way they can be clearly understood over the radio. Just as letters like "D" and "T" have no particular meaning on their own, these letters can be used to mean many different things depending on the context.
The letters could be part of a callsign (to identify an aircraft, e.g. "november four four charlie kilo" is a particular Cessna Citation), taxiways at an airport ("turn right on taxiway hotel" means turn right onto the taxiway marked "h"), to spell out the name of a location when needed to avoid ambiguity, really anything where spelling out one or more letters is required on the radio.
You might want to read up on the basics of how aviation radio communications are conducted to help understand the format of typical communications.
