The natural wind is from 360 degrees at 10 knots. The desired relative wind down the angled deck is 10 degrees left of the ship’s heading at 30 knots.
What heading and speed must the carrier go?
Sign up to join this communityThe natural wind is from 360 degrees at 10 knots. The desired relative wind down the angled deck is 10 degrees left of the ship’s heading at 30 knots.
A carrier heading of 010 degrees at a speed of 20 knots would give you an acceptable solution. You could perform some vector addition to compute the resultant wind and perhaps optimize this somewhat, but in reality the winds are generally not constant enough to make minor adjustments worth chasing.
Even if the winds were calm and the ship was making all 30 knots the crosswind component is almost negligible, and well within limits for any carrier based aircraft. This happens a lot. There is a bigger negative effect from turbulence caused by the island structure when the ship has to make wind than any effect of increased crosswind.
Let’s suppose that the runway is angled by 10º to the left. To start with, let’s assume there is no wind, and that we wish 30 kts of relative wind parallel to the runway. The speed of the carrier (with any heading) will be 30 kts/cos 10º = 30,46 kts.
Now, we have a wind with a speed of 10 knots in relation to the sea. We change the heading of the carrier in order to take the maximum advantage of that wind, so that it may be parallel to the runway. So the carrier steers to a heading exactly 10º to the right of the wind direction. Now we have too much wind, 30 + 10 = 40 kts, and we should reduce the ship’s speed in proportion to that excess of 40/30. In other words, the carrier should steam at 30,46 x 30/40 = 22,85 kts.
Hence, the carrier should have a heading of 10º to the right of the north, and a speed of 22,85 kts...
