In the comments below one of the answers to this question about the influence of temperature on vertical separation, the question was raised whether ATC ensure 1000ft vertical separation based on geometric difference (true altitude) or pressure altitude difference.
In cold air, the true vertical separation will be less than 1000ft if the difference in altitude indicated on the altimeter is 1000ft.
Source: the other question
Is there an offical reference that gives the answer?
The short answer: "Altimeter difference"
The long answer:
From a pilot perspective, when issued an altitude to maintain by ATC, he/she will fly the altitude in reference to his/her altimeter, whether or not it's a "Flight Level" assignment (usually FL180 and above in North America), or "altitude" assignment (below FL 180).
For example, when the temperature is colder than ISA and one aircraft is assigned FL250 and another is assigned FL260 , the actual (geometric/true) vertical separation between the aircraft would be marginally/somewhere less than 1000 ft. There is no ATC correction (in the U.S.) for actual "true" altitude being (probably slightly) less than 1000 ft. in this scenario.
Since there is not an automatic correction for colder than ISA (or warmer than ISA) internal to the altimeter, true altitude is different than what is being displayed to the pilot on his/her altimeter and being displayed to the controller on ATC radar.
This is only with respect to separation between aircraft. Separation from terrain is considered both by the pilot and ATC, as necessary. For example, at some locations during very cold temperatures, MVA (minimum vectoring altitude) for a specific area may be raised so that aircraft always have the necessary "true" altitude separation from the terrain while being vectored by the controller.
The pilot, while conducting instrument approach procedures at specifically designated airports, will make altitude adjustments for the IAF/IF/FAF/MDA/DA/missed approach holding, based on a correction value obtained either automatically from the onboard equipment, or manually from a cold temperature altitude correction table/chart.
On these occasions, the pilot has the obligation to notify ATC of the altitude adjustments being made. These adjustments will be made to the indicated altitude being flown for the purpose of obstacle/terrain clearance and the indicated altitude on the altimeter will be higher than published on the chart.
Air Traffic Control provides vertical separation based on pressure altitude.
ICAO Document 4444 (Procedures of Air Navigation Services - Air Traffic Management) section 5.3 defines vertical separation.
5.3 VERTICAL SEPARATION
5.3.1 Vertical separation application
Vertical separation is obtained by requiring aircraft using prescribed altimeter setting procedures to operate at different levels expressed in terms of flight levels or altitudes in accordance with the provisions in Chapter 4, Section 4.10.
The vertical separation minimum (VSM) shall be:
a) a nominal 300 m (1 000 ft) below FL 290 and a nominal 600 m (2 000 ft) at or above this level, except as provided for in b) below; and
b) within designated airspace, subject to a regional air navigation agreement: a nominal 300 m (1 000 ft) below FL 410 or a higher level where so prescribed for use under specified conditions, and a nominal 600 m (2 000 ft) at or above this level.
Note.— Guidance material relating to vertical separation is contained in the Manual on a 300 m (1 000 ft) Vertical Separation Minimum Between FL 290 and FL 410 Inclusive (Doc 9574).
This explains that the separation is based on altimeter difference of 1000ft. It does not mention low temperature correction when it comes to vertical separation.
Low temperature correction is applied when it comes to the minimum vectoring altitude. Of course the height of obstacles does not change with low temperature so here a correction is needed to avoid collisions risk.
8.6.5.2 When vectoring an IFR flight and when giving an IFR flight a direct routing which takes the aircraft off an ATS route, the controller shall issue clearances such that the prescribed obstacle clearance will exist at all times until the aircraft reaches the point where the pilot will resume own navigation. When necessary, the relevant minimum vectoring altitude shall include a correction for low temperature effect.
