I know cold air is better for engine performance in general, colder air is also denser making lift components stronger(from what I understand).
I was just wondering if there is a temperature or a range of temperatures that offer the best performance overall?
Is there a temp that covers all areas such as takeoff/climb performance, cruise etc. or is it something where each performance area has its own "sweet" spot?
Let's use common flight trainers like the C172 as the example.
    $\begingroup$ The best horsepower listed is at -20C in the 172S POH. I always thought the engine made full rated horsepower at sealevel, 29.92 on the barometer, and 59F (standard temperature and pressure). I don't see anything in the POH to back that up. I don't have a separate engine book to see if if might be there. $\endgroup$ – CrossRoads Nov 9 '18 at 14:44
Good Evening Alex, just for the record I'm a Private Pilot with about 150 hours of flight time, I would recommend speaking to a Flight instructor if you have any more questions about Aircraft POF. (principles of flight and performance)
Best Performance can be narrow down to a simple formula
Best Performance = High Pressure + Low Temperatures
1 hectopascal is equal to 30ft change
1ยบ celsius is equal to a 120ft change br>
If you are looking for the landing and T/O I would suggest looking a Performance charts-which
By clicking โ€œPost Your Answerโ€, you agree to our terms of service, privacy policy and cookie policy
