There are two windows marked with a black triangle, which indicate that they provide the best view for the wing, when the crew needs visual.
Since A320s are probably the most popular birds out there nowadays, in which row are these best-view windows?
It would be nice to take that seat when I check-in in my next flight.
    $\begingroup$ What does this black triangle placard on board an A320 denote? $\endgroup$ – mins Nov 9 '18 at 15:02
  • $\begingroup$ Row 9 then @mins, thanks and sorry for failing to find the dupe earlier. $\endgroup$ – gsamaras Nov 9 '18 at 15:03
    $\begingroup$ Doesn't that depend on the seat configuration ordered by the company buying the aircraft? $\endgroup$ – a CVn Nov 9 '18 at 15:05
  • $\begingroup$ @αCVn probably you are right, but it should be somewhere nearby... ;) $\endgroup$ – gsamaras Nov 9 '18 at 15:07
    $\begingroup$ Whelp, here it is in a pastebin - Note that it shows the triangle seat is not the best seat for passenger viewing. pastebin.com/v7bG0Uic - I'll wait for the day the question "Is the triangle-marked seat best for passenger view?" pops up! :) $\endgroup$ – M28 Nov 9 '18 at 15:13
