Suggest me any reference to compute the torque requirement for actuator/motor to control the pitch angle of propeller (Variable Pitch Propeller).
Thanks in advance
Arun Ravindran
    $\begingroup$ Welcome to the site @ArunRavindran. This sounds like a homework question, and it's a bit vague to be honest. what have you looked at already? $\endgroup$ – GdD Nov 5 '18 at 13:32
  • $\begingroup$ Most variable pitch propellers are controlled by a combination oil pressure, counterweights and springs. I am not aware of any that use an actuator or motor to control pitch. If you do a Google search you will find lots of graphics and tutorials explaining how they work. $\endgroup$ – Michael Hall Nov 5 '18 at 20:25
  • $\begingroup$ Thanks for the advise. We are currently working on design of large UAV class platform. I have came across few techniques where people have used servo/motor to control the pitch angle (beta) variation during their flight to attain optimum efficiency throughout the flight envelop. Please verify Summary of Propeller design procedure and data Vol III - they have given brief explanation about actuator based variable pitch mechanism. Even they have given the calculation for centrifugal twisting moment (torque required to change the beta angle). $\endgroup$ – Arun Ravindran Nov 6 '18 at 5:56
  • $\begingroup$ Problem is they have used a constant value without any reference. Kindly suggest me any reference or method to compute the torque required to change the beta angle of blade. Thank you once again. $\endgroup$ – Arun Ravindran Nov 6 '18 at 5:56
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
