How is shear centre of a wings calculated? i.e. how can I calculate the wing shear centre of a two spar wing with main spar at 0% of wing chord and rear spar at 75% of wing chord? (Assuming the two spars have the same stiffness.)
1 Answer
I implemented a program using Matlab for S.C calculus purposes (I'm actually involved in an aircraft project and, fortunately (or not), I'm the structures guy. I have based the code and the theory in a PDF bibliography that is linked w/ the .zip folder. You'll notice two matlab codes:
-One is named "Load_Airfoil_Coordinates_using_MATLAB.m". It loads any .dat file (i.e., if you have your airfoil points, you can plot it using this code);
-Another is named "Matlab_script_for_the_shear_center.m". It calculates, beyond your airfoil's C.G (Xcg,Ycg), the shear center (Xsc,Ysc) - probably you'll need to change some of the inputs to agree with your problem, specifically. Despite I've commented the most part of this code, I recommend you to follow Perini's theory (PDF bibliography) to understand the steps.
To download the .zip folder, please click my OneDrive link: https://1drv.ms/u/s!Aqqj-vTtH2vbomM9cVTInsHp7dbn?e=PMFudZ.
If you're just focusing on the theory, I recommend you some bibliographic references, such as:
T.H.G. Megson - Introduction to Aircraft Structural Analysis
David J. Peery - Aircraft Structures
B. K. Donaldson- Analysis of Aircraft Structures
Hope I was helpful.
Best regards, João Cioffi
$\begingroup$ Can you update the Drive link of the code? I am trying to calculate a similar thing for the wind turbine blades. Thank you $\endgroup$ Apr 5 at 20:02
1$\begingroup$ @SushilSharma: note that "João Cioffi was Last seen more than 3 years ago"... Most probably you won't get any feedback from him. I'd suggest you to write a new question. $\endgroup$– sophitApr 6 at 8:11
