In a real flight, when the speed of an aircraft increases, we see an increase in temperature too. So that at high Mach numbers the surfaces of the aircraft will be very hot.
Now I have encountered this issue that in a wind tunnel and for a test model it works in reverse order. So that the flow velocity in the tunnel is increased, the temperature of the test model surfaces will reduce, and at high Mach numbers, we need to use heaters to prevent freezing.
My question is this: is this fundamentally correct? If it is, what's the reason for this difference?
I believe the reason is that the air is cooled while compressed in the high pressure reservoir before the high speed wind tunnel.
When moving air is stopped (as happens around the leading edges of the aircraft), its pressure increases (per Bernoulli's principle) and since the compression is adiabatic (no heat exchanged (yet)), its temperature also increases. The final temperature is called Total Air Temperature (or stagnation temperature).
For flying aircraft, the total air temperature is its original temperature plus the increase due to compression by the leading edges of the aircraft. That's why the leading edges heat up in supersonic flight. The other sides don't, the air is not stagnant around them.
However, for wind tunnel, the air was already stagnant in the high pressure reservoir before it—high-speed wind tunnels usually pre-compress the air, because compressors can't produce supersonic speeds. It this reservoir it cools down, and then as it accelerates down the wind tunnel, it adiabatically expands, reducing its temperature well below ambient. It returns to the temperature in the reservoir at the leading edges, but around the rest of the model the air is not stagnant, so it has the lower temperature of the flow.
  • $\begingroup$ Hides your answer is perfect save one small detail. Compressing the air in storage will heat it (PV = nRT). Once compressed, it will cool to ambient temperature, but is still compressed. When it is released (as you explained), the pressure (there for temperature) will drop. Lining up pressure cylinders and using the cooling effect in sequence is how they first made liquid oxygen! $\endgroup$ Oct 25, 2018 at 10:26
  • $\begingroup$ Hides? @Jan Hudec! Sorry. $\endgroup$ Oct 25, 2018 at 11:11
