I want to find some FOD examples of huge planes in reason of ground vortex,where should I go to search?
    $\begingroup$ What does "FOD examples" mean? $\endgroup$
    – CrossRoads
    Oct 22, 2018 at 11:49
    $\begingroup$ @CrossRoads Presumably, examples of incidents involving foreign object damage. $\endgroup$ Oct 22, 2018 at 14:01
    $\begingroup$ How does "Ground Vortex" come into play? A just departed plane would create a vortex that could drift down. ATC makes planes wait to depart behind one in order to give any vortex a chance to dissipate. $\endgroup$
    – CrossRoads
    Oct 22, 2018 at 17:14
    $\begingroup$ @CrossRoads I think they're referring to the vortex that forms on the ground towards the intakes. A Google image search for c17 ground vortex shows the phenomenon. $\endgroup$
    – Sanchises
    Oct 22, 2018 at 18:25
  • $\begingroup$ The NTSB search might bring something up still. $\endgroup$
    – CrossRoads
    Oct 22, 2018 at 18:29
You can search the National Traffic Safety Board here
https://www.ntsb.gov/_layouts/ntsb.aviation/index.aspx
as a starting point.
Under Aircraft:Category, select Airplane.
Under Model, Select C17.
Scroll down and select Submit Query.
There are couple of hits on C17s on the first page of results, I didn't look at further pages.
Try this stack exchange link also on the same occurrence, but not just limited to C17s.
How does this vortex form inside a jet engine?
