Presuming an ordinary long-haul flight on which the plane's navigation system has selected a point as Top-of-Descent, and there are no particular issues (such as weather), when would ATC typically be contacted? That is, would the pilots seek to obtain ATC clearance for descent in advance of reaching TOD so that they could start down at exactly that point? Would the pilots cross TOD and then call ATC to ask for clearance? Would there be a point when the pilots get early clearance to descend once the TOD point is reached but wait awhile to hit the TOD point?
  • $\begingroup$ When flying VFR you don’t have to tell ATC that you are changing altitude. But I always do and I tell them that I have the latest ATIS for my destination. It doesn’t hurt to let them know what you are doing and eventually they are going to ask you if you have the ATIS anyway. $\endgroup$
    – JScarry
    Oct 19 '18 at 15:53
There are some variances in the way a pilot/crew may handle the initiation of a descent (at or near the TOD point as described in your question). My answers below reflect my preferences based on normal circumstances. (IFR Jet operations in U.S.)
  1. If I had not received a descent clearance when approaching (a couple of miles before) the displayed TOD I would request a descent clearance from ATC. This would help avoid being too high and perhaps struggling to meet some published altitude restrictions (e.g. if on a STAR, etc.).
  1. I would not wait until I'm past the TOD (typically) to ask for a descent clearance - see the answer above.
  1. (I'm not entirely certain I fully understand this question) - Prior to reaching the TOD, ATC may issue a "pilot's discretion" descent clearance (e.g., "descend at pilot's discretion, maintain flight level 210"). Then I could wait until the TOD point (displayed on my nav equipment) to start my descent. Or I might get a "descend via" clearance on a STAR (Standard Terminal Arrival procedure) which would authorize a descent to comply with the STAR profile, and based on where I was, I could wait to start the descent at my discretion (as long as I comply with the STAR profile).
  • $\begingroup$ I think he meant "before the TOD point is reached" in the question. I think you answered it precisely in #3. $\endgroup$
    Oct 19 '18 at 22:56
