I'm trying to figure out the calculation to these questions:
A pilot tracking a VOR turns 90 degrees from current heading. The pilot notes that it takes 3.0 minutes for the plane to intercept the radial 5 degrees from where it previously was. What is the time to VOR?
And:
Using the previous question, what is the aircraft speed if the distance to travel is 100 miles?
I used the formulas my professor gave me and the numbers are coming out unrealistic to me. Could someone walk me through how to get the correct answer?
Here is the formula you are looking for: (You can use this formula to answer your first question. I'm not entirely clear on what the second question means.) enter image description here
Here is a nice discussion of the time/distance check from the Flight Learnings website: time/distance to station
  • $\begingroup$ Thank you! I was thinking that the result was seconds to station not minutes because you had to convert minuses between bearing to seconds! $\endgroup$ Oct 15, 2018 at 19:33
