My primary question is: what is the importance of Mach number (M) on shock waves? Although I believe confirming and/or answering the below will help clarify my misconceptions.
When a wave moves faster than the local speed of sound ($c_s$) in a fluid, there is a shock wave since the fluid is unable to respond to the moving wave. Even if velocity ($v$) is constant, if pressure ($p$) varies, there can be a shock if the local speed of sound is exceeded (i.e. $ v \geq c_s \rightarrow M \geq 1)$. Therefore, to confirm, isn't there always a shock wave present as long as the wave is supersonic? Does simply the type of shock (e.g. normal, oblique) change as alluded to here?
Also, is there any difference from $M = 1$ shock waves and $M > 1$ shock waves? For example, this article describes a shockless transition from supersonic to subsonic flow, but what does that conceptually mean?
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
