Would it be possible to weaken the wake vortices generated by a large aircraft (which can be dangerous to smaller aircraft behind the large aircraft, and are the limiting factor determining how closely aircraft can be safely spaced in the air) by shaping the tips of its wings so that the lift generated (and, thus, the amount of air deflected downwards) by the outermost portion of the wing drops off gradually to zero, instead of abruptly transitioning at the wingtip from “lots of lift, lots of downward-deflected air” to “no lift, no downward deflection of air”?
Diagram of what I’ve got in mind:
This would come with a slight efficiency penalty (equivalent to slightly decreasing the length of the wing), but could still be useful in some situations despite this (such as high-frequency operations by a mix of heavy and less-heavy aircraft in heavily-congested airspace, or large numbers of takeoffs and landings by both heavy and light aircraft on closely-spaced parallel runways), and the reduction in lift generated by the wingtip would offset some of this penalty by reducing the upwards bending force on the outer portions of the wing (and thereby reducing the amount of material needed for stiffening this part of the wing).
