The vast majority of airframes and powerplants use U.S. standard/SAE hardware. Which manufacturers of engines and airframes use metric hardware?
$\begingroup$ I believe there was a hardware spec used in Europe called ASN that was metric and was used in some European GA airplanes. $\endgroup$ – John K Oct 9 '18 at 20:54
$\begingroup$ Related: Are an aircraft's nuts and bolts generally either all Imperial or all Metric, or can they be mixed? $\endgroup$ – fooot♦ Oct 12 '18 at 21:25
$\begingroup$ @fooot thanks fooot. I’m aware of this post and have read the whole thing. While some good points are made, it doesn’t really answer my question... only a few examples are given. $\endgroup$ – Pugz Oct 12 '18 at 21:26
$\begingroup$ You mean imperial measurements vs metric? RR use both, depends on the engine. $\endgroup$ – Notts90 supports Monica Oct 13 '18 at 9:51
$\begingroup$ @Notts90 some use US standard, some use imperial, but I am specifically interested in who uses metric. $\endgroup$ – Pugz Oct 13 '18 at 12:54
All use metric dimensions, only the numbers look sometimes rather odd.
This statement is more serious than it might look, in some places you order parts in metric dimensions and they come as 3.175 mm or 12.7 mm.
All Russian (and, by extension, all former East Bloc country) engines use metric dimensions. You only see fewer of them.
I am less sure about French engines like the CFM-56 which uses a GE-designed hot section, but the fully French-designed engines use metric, too.
In the GA world the modern Diesel engines are all metric.
$\begingroup$ Can you please elaborate on what you mean by “all use metric dimensions”? I’ve been working on several power plants and airframes - Cessna, Piper, Grumman, Beechcraft (King Airs), P&W PT-6 turbines, Lycoming, Continental, and all seem to use SAE only dimensions and fasteners/hardware. $\endgroup$ – Pugz Feb 1 '19 at 17:44
1$\begingroup$ @Pugz: OK, you didn't get it. Use a metric caliper. Measure some dimensions. You will get metric dimensions, right? Even from a US engine. $\endgroup$ – Peter Kämpf Feb 1 '19 at 23:23
1$\begingroup$ After all, 1 inch is, by definition, exactly 25.4 mm... $\endgroup$ – xxavier Feb 2 '19 at 8:06
1$\begingroup$ @xxavier: Yes, you are right: The imperial units are defined by the corresponding SI units. Therefore, the inch is now defined as 25.4 mm. Want more precision? OK: 1 inch = 25.400000000000000000 mm. Therefore, all dimensions are metric but with odd numbers. This joke has more depth than appears on first reading. $\endgroup$ – Peter Kämpf Feb 2 '19 at 8:31
2$\begingroup$ @PeterKämpf Well, yeah :)) - Then again it's rather shallow, not really working so simple, as metric bolts are made to ISO pitch/lead while 'imperial' bolts are defined by the ANSI maintained "Unified Inch Screw Threads Standard".So while a 3/8 bolt does measure about 9.5 mm, a 9.5 mm nut won't run along. Diameter is just one of 6 major (and mord than a dotzend secondary) values to describe such a simple piece :)) And yes, it's relevant, as the OP asked for SAE specifications. Standards include way more than just the way length is counted. $\endgroup$ – Raffzahn Feb 2 '19 at 16:15
