Been reading all these ICAO documents about APV I and II and none of them clearly describe (from a pilots perspective) the difference. Please help
    $\begingroup$ The ICAO approach classifications have changed. Are you sure the document you read is recent? Check its year of publication please, and add that along with the document's name/number to the question. $\endgroup$
    – user14897
    Oct 8, 2018 at 9:05
The difference between APV-I and APV-II "... lie in the signal-in space performance requirements..." (see this presentation, in particular beginning on page 12: ENAV presentation).
This means that APV-I/II refer to navigation signal performance requirements for APV approaches. Note #8 on page 13 of the presentation referenced above is clarifying:
The terms APV-I and APV-II refer to two levels of GNSS approach and landing operations with vertical guidance (APV) and these terms are not necessarily intended to be used operationally.
Therefore, look at APV-II versus APV-I as providing for lower APV minimums based on signal performance (horizontal and vertical alert limits) at locations where this is possible. Similar in concept, but not in value, as the difference between RNP .3nm and RNP .1nm approaches.
  • $\begingroup$ As far as pilot operation as asked, I'd like to add that according to ICAO, APV approaches now fall under the new classification "3D-Type A", SBAS (LPV) has been bumped up to "3D-Type B". $\endgroup$
    – user14897
    Oct 8, 2018 at 18:47
  • $\begingroup$ Thanks. this helped alot $\endgroup$
    – Dededkd
    Oct 9, 2018 at 10:22
