A timing must be started when flying abeam the threshold on a circling approach. The FCTM of the B777/787 mentions 35 seconds and the SOPs of the Embraer 190 30 seconds. Do they need to be corrected for head/tailwind? If yes, how are they corrected?
Yes, they need to be corrected, mainly for two reasons:
1) Legally, the horizontal criteria for circling is the distance from the threshold of each usable runway (search for TERPS circling criteria if you are interested in US rules, or PANS-OPS circling criteria for the rest of the world). In other words: you need to stay within a given distance of the runway. If you have a very strong tailwind, without correcting for it, you might leave the circling domain.
2) In order to facilitate the base/final. If you have a very strong headwind (which is indeed not very likely, as it means you will land in a very strong tailwind), you will drift towards the runway during your entire base/final-turn. This means you will roll out on the final course a lot closer to the runway than you would in zero wind. This could be a problem, since your stable approach criteria usually requires you to be "wings level" at some altitude (typically 300 ft for circling).
Now, for the how, this will depend on aircraft and operator. One example is however to add/subtract half the wind component in knots from your timing in seconds. Example: Zero-wind outbound: 30 s, Tailwind component: 20 kt. Wind-corrected outbound: 30 - 0.5*20 = 20 s.
(In addition, outbound timing is usually also determined by circling height, since the higher you are, the longer you will need for your descent. A typical SOP here is to take the circling height in hundreds of feet, and multiply it by 3, to get your zero wind outbound timing. Example: Circling height: 1000 ft. 1000/100 * 3 = 30 s.)
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
