33
I was at the California Capital Airshow on Mather AFB over the weekend, and came across a beautifully maintained B-17 Flying Fortress. The crew were kind enough to allow people to go inside and take a look - what a magnificent machine!
While inside, I noticed the dome gunner seems to be in a position to accidentally shoot the tail off the plane!
Are there any confirmed instances of this happening? Was there some way to prevent it - either be it training or some mechanism that stopped the guns while in this position? I can imagine, in the heat of battle, sweeping an enemy fighter and nicking your own tail in the process!
    $\begingroup$ This page contains an account of a waist gunner shooting the tail, but I'm unable to do more research into it at the moment. $\endgroup$
    – Ron Beyer
    Sep 24, 2018 at 16:51
  • 20
    $\begingroup$ If your not careful thats what happens at 11 0'clock $\endgroup$
    – Dave
    Sep 24, 2018 at 18:57
    $\begingroup$ IIRC shooting your own aircraft was a serious risk with pintle mounted machine guns in early WW1 aircraft. $\endgroup$ Sep 24, 2018 at 19:56
  • 16
    $\begingroup$ My grandfather was an air Sargent and gunner on B-17. He told me a story where he had accidentally shot down his plane because the ball turret gun cutoffs were wired shut. These cut-offs were to prevent hitting the aircraft was the turret guns rotated but German fighters quickly learned to approach bombers these angles. This led to crews wiring shut the cut-offs. Fortunately for my grandfather, being the air Sargent, he was responsible for the combat log for the mission and also enemy fighters were encountered so he could report the plane was hit by enemy fire. $\endgroup$ Sep 25, 2018 at 13:10
    $\begingroup$ @DanNeely That's correct. It took the invention of Fokker's interrupter, which automatically repressed fire when a blade was in front of the gun, to prevent this. $\endgroup$
    – forest
    Sep 26, 2018 at 6:35
48
There's a profile cam in the turret track ring that operates a mechanism that interrupts the guns when the barrels are pointed at parts of the aircraft. Waist gunners were the only ones who had to worry about hitting their own plane.
The bigger problem was gunners hitting adjacent aircraft. The "box" formation design attempted to provide as much of an open field as possible to each gunner.
    $\begingroup$ Not just gunners hitting friendly air craft - the bombs themselves have hit planes flying below them as well. Recall watching old WW2 documentaries w/ various gun cam footage and seeing it happen... $\endgroup$
    – ivanivan
    Sep 24, 2018 at 22:07
    $\begingroup$ Didn't the top turret gunner also have the potential (if there were no interrupter mechanism) to shoot part of the plane, as shown in the question? $\endgroup$ Sep 24, 2018 at 23:21
    $\begingroup$ @WayneConrad as far as I know yes the B-17 specifically did have such a feature in the top gunner position. I think that's what John K meant, but there are bombers with such positions that did not have any such mechanism, ahem some German bombers. $\endgroup$
    – Jihyun
    Sep 25, 2018 at 3:45
    $\begingroup$ The only gunners that had the ability to shoot directly into their own airplane's structure were the waist gunners. $\endgroup$
    Sep 25, 2018 at 13:35
    $\begingroup$ @JohnK Would this then be accurate? "Because the top turret gun had an interrupter mechanism, it could not shoot the airplane even though it could aim at the tail. However, the waist guns, which had no interrupter mechanism, could be aimed at the airplane. Therefore, the waist gunners were the only ones who had to worry about hitting their own plane." $\endgroup$ Sep 25, 2018 at 13:45
