I understand the difference between best angle of climb $V_{x}$ and best rate of climb $V_{y}$. When I take off I would aim to maintain one speed or another depending on what I want.
But I don't understand why it's measured in airspeed, instead of pitch angle, which would seem more intuitive.
    $\begingroup$ Remember that Pitch plus Power equals Performance. If you are aiming for a specific performance (e.g. climb rate) then it depends on two things. Power will vary with altitude and temperature, so the pitch will be somewhat different in different environmental conditions. $\endgroup$
    – JScarry
    Sep 23, 2018 at 15:32
  • $\begingroup$ This is done on large jets... immediately after lift-off and on go-around, the flight director will give you a pitch command that will maintain V2+some margin (V2 on engine failure). Airbus calls this the Speed Reference System. It actually is an important safety measure for countering somatogravic illusions. $\endgroup$
    – user71659
    Sep 24, 2018 at 22:46
4 Answers 4
Because determining Vx and Vy has to do with the specific aircraft, specific power output of the engine, thrust from the propeller, etc, which is often a function of pressure altitude and airspeed.
Remember that Vx represents a situation where the aircraft has the MAXIMUM EXCESS THRUST meaning a situation where the difference between the maximum thrust available and and the thrust required to neutralize drag force and maintain straight and level flight is the greatest.
enter image description here Images courtesy of BoldMethod
Vy on the other hand is the point where the aircraft has the MAXIMUM EXCESS POWER available to it, translating into the greatest change in altitude for a given period of time by simple conservation of energy considerations.
The airspeed where Vx occurs increases as the pressure altitude increases. Conversely Vy decreases as pressure altitude increases. This is due changes in power and thrust outputs with increasing pressure altitudes. Vx and Vy eventually equal each other at the aircraft’s absolute ceiling, since there is neither any more excess thrust or power available here for climbing.
  • $\begingroup$ Thanks. But the same could be said about pitch angle as well (dependent on power output, aircraft, ...) My question is, why isn't the Vx Vy on AFM/POH indicated in pitch angle, instead of airspeed. $\endgroup$
    – Hot.PxL
    Sep 23, 2018 at 16:00
  • $\begingroup$ See the first paragraph of my answer. It works out that those values are a function of pressure altitude and airspeed as they are dependent on the amount of power and thrust an engine can produce respectively. $\endgroup$ Sep 23, 2018 at 16:31
    $\begingroup$ Would it be correct to say that, say, a "best-rate-of-climb pitch" would depend on aircraft weight much more than the best-rate-of-climb airspeed does? If so, I think that would answer @Hot.PxL's question. $\endgroup$ Sep 23, 2018 at 22:12
    $\begingroup$ No! There is no specific pitch angle here, only a particular airspeed in which the greatest excess thrust or power is available for climb. One would apply full power during climb and pitch the aircraft to maintain these specific airspeeds in order to obtain the best angle of climb or the best rate of climb. Vx and Vy can vary with weight, however, on larger aircraft, as they have a direct effect on the amount of induced drag created, which in turn affects how much excess thrust or power is available for climb. $\endgroup$ Sep 23, 2018 at 22:34
  • $\begingroup$ @HenningMakholm I understand what you are trying to say, and it does make sense to me. Thanks $\endgroup$
    – Hot.PxL
    Sep 24, 2018 at 0:33
A very simple practical reason is that Vx and Vy speeds can be easily monitored as the pilot is climbing away and controlled with the elevator. This useful information is in the POH to be used by people who are quite busy at the moment, there for it is expressed in a user friendly form.
Climb angle, as a matter of interest, could be studied for a variety of engine, prop, weight, flap setting, etc., but what the pilot needs on the spot is V at full throttle climb.
Let’s say you have an engine problem, or it’s hot and your performance is negatively effected. The angle of attack will be very different to get best climb, but the airspeed will be the same as if you have lots of power.
Pitch angle only corresponds to an angle or rate of climb at a particular excess thrust.
Consider the typical stall exercise: you pull the engine to idle, then apply more and more elevator to try to maintain altitude, thereby pitching up and simultaneously reducing airspeed. At one point, airspeed drops to the point where you lose lift, and you fall out of the sky, despite the fact that you are nose high.
Once you apply power and push the nose down a little, it again becomes easy to establish a climb to regain any altitude lost.
Heck, consider how you slow an airplane down in the air, by raising the nose without having excess thrust.
If rate of climb (expressed as either best angle or best rate) related only to pitch angle or angle of attack, then instead of slowing down, you'd start to climb and maintain that climb as long as the pitch angle is unchanged, no matter the power setting. That's clearly not happening, at least not for long, so there must be something else to determine whether the airplane actually climbs or descends. That factor, as already mentioned, is (excess) thrust.
Therefore, expressing Vx or Vy in terms of pitch angle would require taking into account the amount of excess thrust available. Accurately estimating that directly is non-trivial, at least without specific instrumentation, and would also likely require the pilot to memorize a whole table, rather than a single (or two) indicated airspeed(s). During a high-workload phase of flight, including take-off and initial climb-out, every little bit that adds to the mental workload of the pilot risks increasing the workload beyond the pilot's capabilities.
If instead you aim to maintain a given indicated airspeed, you will be at a point of the power curve where all the factors line up for that airspeed, regardless of the external conditions (pressure altitude, wind, etc.). If airspeed drops for any reason, you pitch down slightly to pick up more speed and maintain the climb; if airspeed rises, you pull the nose up instead to slow down (trading airspeed for climb angle). You're using the pitch angle to maintain an airspeed, and the only instrument you need to pay very close attention to is the airspeed indicator.
